If this is a BIOS password, you'll need to open up the tower and look for a jumper that says 'reset bios' or 'reset CMOS'. Move the jumper to the other pins and turn the computer on. NOTE: check to make sure your model needs to be turned on or not. When it beeps, turn it off. Then move the jumper back to its original position and start normally. Hope this helps.
SOURCE: windows does not load after gateway logo
This sounds like you have no operating system on your laptop. I bet someway, just as I did before, you have lost your operating system, and it needs to be reinstalled on your computer.
SOURCE: booting up
Try to start up with the windows XP CD in the drive, it will give you some options to reinstall or repair XP. If this doesnot work, ensure that your BIOS will startup from CD.
SOURCE: FORGOT BIOS PROBLEM
try to open back cover..there u have to remove the CMOS battery and re insert again..it will reset your BIOS...
SOURCE: Key board not working
It's a hardware issue,
Maybe RAM or hard drive..
Did you get it used? If so the password was set b4 you purchase it, and will not show up when you type,,,It stays hidden.
Your getting this screen because there is a hardware failure. Fix the problem and you wont need the BIOS password.
Press<esc> to enable startup message, This should give you more info on the problem.
SOURCE: Have a toshiba c655 & forgot my password / as
Have a toshiba c655 brand new in the box as soon as I turn it on it- says to enter current password. It will not let me use F2 or F12, it goes right back to enter current password. How can I solve this problem?
