Samsung Galaxy Tab Tablet PC Logo
A
Anonymous Posted on Oct 17, 2014
Galaxy Samsung wont charge battery is totally dead and wont do a thing when pluged in to charger.
Manuel Zarsadias
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 70 Answers
  • Posted on Oct 28, 2014
Manuel Zarsadias
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
70
Questions
0
Helped
12497
Points
89
Try to use other Samsung/Android Charger.
3 Related Answers
KingDWS
Dave King
  • 1606 Answers
  • Posted on Mar 23, 2012
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Anonymous
  • Posted on May 23, 2013
SOURCE: my Samsung Galaxy Note 10.1 battery not charging can you please tell me why
mine still doesnt charge when it's turned off. it just vibrates sporatically. i had to get a totally seperate charger for my battery. it's stupid. so now i have to switch it out all the time
bwint52
  • 5 Answers
  • Posted on Oct 11, 2014
SOURCE: Are there battery recharging problems with Galaxy Note 10.1?
Possible both try charging unit using a friends 10.1 charger if same results in battery been partly charged. The answer is yes its the battery
1helpful
2answers
1helpful
2answers
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
3answers
What to do if my galaxy wont charge
At this level of charge their is not enough to start the boot process , if it doesn't charge at all their may be a fault with the Battery cell , however i had a similar issue, just leave it for a while, if their is still no indication that its charging or it wont turn on their could also be a problem with the Start Button
1helpful
My samsung galaxy tab 2 7.0 wont turn back on
Let it charge for multiple hours before turning it on.
Samsung galaxy tablet 10.1 wont charge show a 1/4 yellow battery then turns off show battery again then shuts off
Either the battery or the charger is done for. If you have family or a friend with the same unit, you can verify your charger and your unit with their equipment.
Good Luck.
Unable to switch on my samsung T210 tablet
5helpful
6answers
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
