Trio Mach Speed Stealth G2 Tablet - Teal in Color- 7" Dual Core Android 4.0 Internet Tablet with Google Play Store Logo
S
Sue Barker-Gordon Posted on Oct 18, 2014
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
larsjohn
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jan 10, 2015
larsjohn
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
11
Questions
0
Helped
3622
Points
15
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Nook tablet service center in hyderabad
Naresh,
This is a sign of a bad battery. I would say replacing the battery should correct the issue.
My battery wont re charge
Try a different charger, if this doesnt work you'll have to consider replacement or repair. Hope this helps, Graham
2answers
Why won't my pronto tec 7" tablet turn on?
Sometimes on these types of devices, you need to either hold the button in or pull the battery out temporarily to get them to boot.
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
I am trying to charge this tablet. After hours, it is still showing an empty battery when I try and turn it on.
Check its charger first. If there is no power output from the charger, the battery won't charge. If it is found OK, surely the battery inside your tablet is bad; should be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Top Trio Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Trio Tablet and eReader Expert? Answer questions, earn points and help others
