Tablet has been plugged in for about 3 hours for charging but will still not power on. It is less than a month old.
Have you pressed and held the tablet switch for a minute? Usually this feature is adopted to stop the tablets and smartphone for accidentally switching them off of the first press. So, it was suggested that the press and hold for about a minute to switch it on or off. if it is not the case, have you checked if your battery is not reverse polarized? In some smartphone this is an occasional occurrence where people replace batteries the wrong way around.
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
SOURCE: kurio kids tablet won't start up
I fixed mine like this, unfortunately you will lose all your data on the system.
1) Whilst holding down the Power button, hold down the Volume+ button for about 10 seconds and let go.
The table should boot into a screen with an Android with a open chest and a danger sign on top.
2) Press the Volume+ button, and the recovery menu will appear.
3) Press the Volume- button, to move to "Wipe data/Factory Reset" and press the Power button to select that option.
4) Press the Volume- button to move to "yes" and press the Power button to accept.
Now the system will wipe the data and factory reset the tablet.
5) When it returns to the menu, make sure it is on "Reboot system now" and then press the Power button.
The tablet will now reboot and should load.
