Samsung DMT300RFW Builtin Dishwasher Logo
A
Anonymous Posted on Oct 18, 2014
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
Ronald Rissel
Level 3:
Master:
  • Samsung Master 715 Answers
  • Posted on Mar 12, 2015
Ronald Rissel
Samsung Master
Level 3:
Master:
Answers
715
Questions
Helped
259004
Points
1075
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
3 Related Answers
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 27, 2011
SOURCE: I have a DMT300rfw samsung dishwasher. The other
Hello, jduffy
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
mc1bean
Mike Cairns
  • 3054 Answers
SOURCE: samsung dishwasher model dmr77 runs for 3 mins
Hello, kurt
Anonymous
  • Posted on Dec 21, 2012
SOURCE: SE error code on Samsung dishwasher
5E code. If your dishwasher has been running fine for awhile then throws a 5E code chances are it could be the pump or a blocked hose or filter but chances are its not. 1. Does the code come on after it has gone through the wash cycle and released the soap dispenser? or 2. Does the code show afer 1 or 10 minutes of running without the wash cycle completing, soap dispenser still closed?
Number 1 is easy to check just diconnect the drain hose and run the hose into a bucket to see if the hose or filter is clogged or pump is working. These machines only use about 2 gallons of water and the pressure is very low its easy to do in a bucket. If number 2 occurs, its not a clogged hose or filter or pump issue the machine is not even cycling.
If number 1 checks out ok you have water flow but shuts down and number 2 has occured, its your Case Level Sensor its the electronic solid state float, DD94-01006A its either sticking due to water impurities or its bad.
Its actually pretty easy to trouble shoot or fix. You have two choices but the machine has to come out. The sensor is located behind a metal plate on the lower left side ofthe machine. You can;t miss it it looks like a float, has a black float inside a clear plastic housing and some wires going to it. You can pull it out and clean it (The float should go up and down with no sticking at all). Or just buy a new one $35.00ish and put in. Also check the inlet hose to the float make sure its clear and clean DD67-0057A.
There is one catch to this that can cause lots of grief if ANY water at all comes out of the float while changing it. If any water gets in the bottom of the catch basin underneath, the very very sentive probes will detct it and throw a LE code and the washer will not work. that is not a big deal just need to pull the basin off and dry it out. The smallest amount of water can cause the sensors to react since its a protection system.
Samsung dishwashers are very quite and wash extremely well but there technology and engineering sucks along with their warrenty and repair manuals there are no manuals for the home owner or much for the repair guy.
That float will have problems again and again and again either its dirty or broken and will cause another 5E code situation.
Side note; food grinders in a dishasher are stupid! All dishes places in a dishwasher should be rinsed! A domestic dishwasher should not be used as a disposal. It makes your house stink and tons of bad bacteriea will grow in places you do not want it to, not to mention they are not made to work like you would think.
Best dishwasher with the least trouble, easy to fix, easy to dignose, easy to work on, good manuals, few problems, good warrenty, best built, quite running, washes great, very well engineered is BOSCH.
Terry
Don't know enough from your description. Does the pump hum, or empty the washer? There's a strainer under the lower washer arm that may be plugged. If the pump doesn't engage at all, my first thought would be the timer portion of the control board. I'd guess the control board would run about $125 or so.
Oct 18, 2014 • Dishwashers
Machine power on off and other butons not responding
A lot of these Samsung dishwashers don't have fuses; or the fuses are incorporated (soldered in and sealed) inside the dishwasher controller (electronic control module); which is unfortunate, because it means that you have to replace the whole electronic control module, which is a fairly expensive proposition.
2answers
Samsung dishwasher DMT300RFW "Case brake assembly" is overflowing
Yeah, you're probably going to have to replace that case-brake assembly. Fortunately, they're not very expensive. Check with SearsPartsDirect.com or RepairClinic.com
Why does our Samsung DMT300RFW dishwasher have a terrible odor coming from it ?
Usually caused by a draining problem. Check your drain hose where it goes into you garbage disposal. That drain hose should be mounted up so water from the sink and garbage disposal can't backwash into the dishwasher. Use a clamp or zip tie to mount the drain hose so it goes up at least 4 to 6 inches above the garbage disposal port.
How do I reset a samsung dmt300 dishwasher
i have a samsung DMT300 Series. The heavy light keeps blinking. How do I reset it? It was leaking water and I believe we fixed it. What can I do?
2helpful
3answers
Bosch dishwasher starts, pumps, stops and says it's clean
Here is what I found that makes my bosch dishwasher come on. It has the same problems as the OP. I pick the cycle I want press start. The DW will sound like it's trying to drain. I let it run that cycle which takes about 30 seconds. It then starts another cycle that sounds different from the first and when it stops I turn the DW off and then back on, it resets and then it starts the wash cycle. I've done this twice and it has worked both times. I do not know what is causing this but it's better then what I had to do to get it to reset.
7helpful
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
MDB7749AWB
Hello I had the same issue the sequence for resetting the panel is;
heated dry...normal...heated dry...normal
all the lights will go on then off. on my machine it started the normal wash cycle. I let it run normally so far this worked.
Hope this helps.
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
