My Tablet isn't charging properly,even when left on overnight,and the screen just jumps from a battery with a buffering symbol to one with a low charge! What do i do?!
SOURCE: i need to download user manual for samsung galaxy
You can download the available documents from the following website.
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP01&searchWord=galaxytabpc&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=galaxy+tab+pc+
Please let me know if you require any further assistance.
Thanks
SOURCE: How do I know when my Samsung Galaxy Tablet is
The Tab takes quite a long time to charge (not sure why). Note that the Tab cannot charge from a computer USB port (only from the included AC adapter. When the Tab has finished charging, it should put out a notification (open the notification drawer by pulling down on the status bar) saying the battery is fully charged and to unplug the charger. Other than that, you would have to install a third-party app like Smart Battery Monitor (see here) and watch that to see when it is full.
Hope this helps,
Alistair
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
SOURCE: why is there a red cross on the battery icon of galaxy tab though its fully charged?
I studied my galaxy note 10.1. when i use the original wall charger it charges well, fast an no red cross appears. when i hook it to the usb of my laptop then the red cross apears and the tab reports that it is not on battery ( look at the time on battery it does not change) the battery also remains at the same charge level that it was when i hooked it up. when i use the car charger it does the same as with the laptop. my conclusion is that when hooked to the car and/or laptop the battery does not charge, but the tablet is running of the power from the external source and not the battery. this seems to be a very clever move from samsung to preserve the battery when it cannot be charged by the device it is hooked up to.
SOURCE: samsung galaxy tab 2 10.1 wgxa model GT-P5113 is frozen
Hold the power button down for up to 15 seconds. This should hard reset it. Not to be confused with erasing data.
