Lights blink on and off, wont change settings and wont turn on
Typically, that would be caused by failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
There should be an electrical schematic diagram attached to the back of the unit. You may be able to use that to identify the faulty part. Don't be surprised if the replacement board costs alot more than it's size and simplicity might indicate.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
have you tried unplugging it for about 15 minutes and plugging it back in?
