Question about Fisher Paykel EcoSmart GWL15
Fisher and Paykel GW712 Washing Machine - beeping & flashing continuously
We're wondering if we can fix this problem without having to spend $ on a technician. Machine was working fine until we moved it to clean behind. Now when you turn the POWER button on, it flashes 2 yellow lights in the program lineup (5th and 6th from the right) and the red spin (the 1st on the right). It beeps continuously unless you press another button but even then, the flashing lights stay flashing and nothing happens.
Would very much appreciate any help you can give us!
With thanks
Paul and Julie, Sydney
  • 3 more comments
  • lulukay Jan 16, 2008
    i could not explain it better ... is this a manufacturer fault. Everything was fine until one morning it just goes with this beeping and flashing continuous problem.
    I tried to switch the power on and off or press other buttons but it just stays frozen until you press the power button again.
    It is only 3 years with me.
    Lois
    Suva, Fiji
  • Gordon perth Feb 08, 2008
    Also GW712. Same sort of problem. Constant beeping, 2 midcycle lights plus a red spin light. The beeping can be stopped by pushing any button and the 3 lights go out but then the lid locked' light stays on and the maching won't do anything - even though the lid is not locked. Started about 9pm - the machine had not run for hours.  Power off for several hours has no effect.
    Gordon, Perth.
  • Anonymous May 21, 2008
    Lights are on and beeping occurs but the motor seems to falter. The water is going in but the wash and rinse cycle don't operate for more than about 10 secs. Tried turning off power and unplugging from wall (like a laptop) Wonder if the machine was overloaded to begin with. Took all articles out and tried again but the problem is still there
  • nomes23 Apr 18, 2009
    my third and fourth light and the end spin light stays on and beeps it does nt stop beeping till u press the start button and then the lid lock light stay s on and that s all it does please help thanks
  • millsjam May 11, 2010
    my f & P GW712 stopped before the rinse cycle error 39 or 23 can't quite remember which green light I'm pretty sure it was 32,4,2,1 lights that were on can you give me some advice as to which direction to head as the machine is only 3 years old and has run well 'til now and we don't want to waste $ on a call out to only be told it can't be fixed or that it would only cost a small amount for the part that my hubby could've replaced thanks millsjam
    New Friend:
My gw712 washing machine will fiil up ok but then it wont spin properly it only spins a fraction then stops and starts beeping the second led from the left starts flashing. any help would be greatly appreciated.
Posted on Apr 06, 2011
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Error 49. Its a water solenoid. Replace it. I got one on Ebay for $40 delivered. Still had the problem. Below is my solution. I didn't ant to pay for a new controller. They aren't worth it. Must cost about $30 to make them!
I replaced the solenoid but still had binary 49 LED code. I chased the circuit through the Motor Controller (brown one in Australia) GW712.
It was a couple of FETS or Qs in a H drive. The get fed their +v from the main power rectifier. There is a funny looking round component called F^ which is a quick blow 1.6 A fuse. Because my solenoid had a shorted turn on it (bubling to outside packaging) it had blown this.
I didn't have one instock so I substituted an ordinary glass 2AG 2.0amp fast blow. You need to remove the old fuse and solder 2 wires into the holes left these are inturn soldered to the fuse ends. I used hot glue to hold the fuse clear of any other components.
You can get slow blow fuses almost anywhere. In my experience ordinary fuses are the same they always fail after the components are lost anyhow!
If you are desperately dirty you could just jump the 2 holes with tinned copper but this could represent a fire hazard if a solenoid goes again.
We amke microcontrollers. It is a simple fix and saved me $350. A fuse is 10c or maybe $1 if you buy them one at a time. Make sure you test the plugs before you start up. My GW712 read:
1. Each motor winding ~ 35 ohms to any other
2. The lid solenoid ~ 70 ohms
3. Each water solenoid ~ 60 ohms
4.The thermistor ~ 10K ohms
# When this fault exists you can empty the water by removing the tube to the Pressure Xducer and using a tube from your mouth to blow into it HARD!!! The pump will start and pump it out for you.
To calculate the error code (for what use that is when you can find out)
LEDS indicating wash cycle
X X X X X X X X
128 64 32 16 8 4 2 1
Add the values for each light LED
Posted on Mar 20, 2008
  • Andre Bonhomme Nov 16, 2013
    my error code is 130
Check the out of balance switch which is located underneath the motor controller panel. It is a small rectangular flat piece with two wires going to it. If you see any corrosion then you will definately need a replacement part (which had fortunately been improved on since the original).
Posted on Jan 09, 2008
    President:
  • 1,294 Answers
Are the water faucets connected well; is the exit hose at about three feet high from ground level & then into the standpipe? Is the faucet open fully before you start the machine........
If it still flashes, press "end of cycle" button for over 5 seconds to clear screen.
Dont forget to rate..........
Posted on Dec 28, 2007
6ya staff
SOURCE:
Fisher and paykel model gw712 . During rinse or spin cycle unit goes out of balance and stops. The rince or spin light flashes and a beeping sound is heard.
your clothes load is too heavy on one side; stop it move some around and turn it back on and see if it doesn't wobble all over.
Jun 06, 2015 | Fisher and Paykel Washing Machines
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Mar 27, 2011 | Fisher and Paykel (IWL12)
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
16,477 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
