Every 8 or 9th picture is ruined because of multiple exposures combining 2 or 3 photos into a single picture. The camera says unable to view pictures but this can be seen when they are downloaded to my PC
SOURCE: Nikon D70 will not take photo
did you try a master reset? my d80 can do a factory reset i'd be surprised if the d70 does not have this feature, look in the manual or download it from nikon's web site
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
I had the same problem with my CoolPix5400 and this resolved the issue.
SOURCE: Cant take photos as it says the card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
SOURCE: My D90's multiple exposure won't turn off !!
Have you tried going into the menu and finding "reset"?
Testimonial: "thats a great idea thank u so much. Would u happen to know in which menu i can find the reset ?"
SOURCE: I am trying to download pictures from my Nikon
Must install the camera's driver on to your computer before plugging the usb cord into the PC.
I would as a rule install the camera's software from Nikon.com's support site if it did not install automatically.
http://www.nikonusa.com/Find-Your-Nikon/Product/Digital-Camera/26191/COOLPIX-S8000.html
It can sometimes be difficult to setup a digital camera on a new computer. Usually the process is simple: plug the camera in, allow the system to install the driver and begin using the system, however, sometimes things can go wrong. Following these steps can solve more than 90% of problems relating to USB connection issues. You must be thorough and follow it step-by-step.
A large number of problems are caused by incompatible CF Cards. In many cases these cards will work while shooting but can fail to properly download to the computer. You must be extra careful that the card is approved. Actually look up the card you are using in the manual to see if it on the list. Many retailers include "Unapproved" cards in their bundles, so just because a card came with the camera doesn't mean that it is "Approved".
If in doubt, use the "Nikon Starter Card" for testing.
While PTP mode can be used if your camera and operating system (Mac OS X and Windows XP) supports it, for troubleshooting it may be useful to switch to MSC USB mode using the camera's setup menus.
Nikon View will not auto launch or give a transfer window with no images on the flash card. If you have covered the first three items you should now connect the camera to the rear USB port (not through a hub or front port) on the computer. On all Windows systems excluding Windows 98 Second Edition (SE) ("Plain" Windows 98 is not supported.) make sure the Nikon View CDROM has been removed from the system prior to connecting the camera.
If you are not getting the "Found New Hardware" wizard then check the LCD display. If the display stays "on" and the camera seems to be in Shooting mode or Playback mode then you may have a bad cable, camera USB port or computer USB port. If this is the case, contact Nikon Support for more information or Click Here for more troubleshooting.
If you connect the Camera and a "Found New Hardware" wizard comes up you should allow the system to auto search for the driver by simply clicking the "Next" button until it is finished. (Windows 98SE requires the Nikon View CD-ROM to be in the CD-drive at this point.) On Windows systems newer than Windows 98SE the camera should pick up and use the Microsoft Mass Storage driver.
You need to understand how hardware handshaking works. The hardware Handshake occurs when a USB device is connected to the USB port. The computer detects the USB device on the USB bus and asks: "What are you?" The Coolpix line of cameras should answer: "I am a Nikon Coolpix 5700 currently set to Mass storage mode."
If the computer does not understand this message the most likely cause is an incompatibility with the USB chipset on the particular USB controller that the USB port is connected to. You can check your controller chipset on the Microsoft Hardware Compatibility list. First find your "USB Controller" (i.e. Intel 82801AA USB Host Controller) in your computer's "Device Manager" and then look it up on the above link. You can tell if the handshake failed if the camera is listed in Device Manager under “Unknown Devices” or “Other Devices”.
The Mass Storage Driver set consists of two drivers. The first driver is the “Mass Storage Driver” ("Nikon Mass Storage" driver on Windows 98SE systems) and the second is the driver for the CF card in the camera. The CF Card driver should be listed under “Disk Drives” in Device Manager. Be sure both drivers are installed and showing up cleanly in Device Manager.
If both drivers are installed "cleanly" in Device Manager (no question mark or exclamation point) then you do not have a camera or driver issue. If Nikon View does not “Auto Launch” or the Nikon View “Transfer Window” comes up but fails to transfer images then the you can usually resolve these problems with the following steps. Nikon View is not required to transfer images from Nikon Coolpix camera’s capable of running in Mass Storage Mode.
Double click on “My Computer" and verify that a “Removable Disk” icon with a drive letter is listed. If the "Removable Disk" is not listed then there may be Network Drives mapped with drive letters that follow the last actual local drive listed. If this is the case Click Hereto learn how to change the drive letters to accommodate the Removable disk
There are two simple ways of transferring images:
a) You can click through the directories on the removable disk: i.e. "g:\DCIM\100Nikon" and copy the entire contents of this directory then paste into a local drive location such as "c:\My Documents\My Pictures."
b) The second option would be to launch Nikon View and select the removable disk from the folder list on the left. With the removable disk expanded down to the "100Nikon" directory you can "select all" and drag the images to a local drive location listed on the left.
If Nikon Transfer starts but fails at any point during the transfer then there may be some bad picture files or corrupted data on the flash card. This will sometimes occur if the card has been used in a card reader to move non-picture files between various computers.
Note at which file number the transfer is failing and go through the mounted removable disk to delete that picture file. You can also copy all the picture files except the damaged files from the card. Always format the flash card in the camera after you have recovered the undamaged picture files to the computer.
