I need to get the previous owner removed from the ipad or factory reset the whole thing
You can try this: Go to Settings. Under Settings, scroll down to General. Click on that. Under General, scroll down to Reset. Click on that. That will open several lines of choices. The second one is "Erase all content and settings" - however, I have not ever tried this, so it's possible you will need the previous owner's Apple ID and password to complete this step. I would suspect you will, because Apple is very serious about security. So you may need to either contact the owner and get the ID and password, or your other option, as you said, is factory reset, which may be your only way out.
If iOS 7 is installed on the device then this is a built-in security measure against theft to prevent a thief from erasing content and using as new. You will need to get in touch with the original owners.
Don't forget to plug in the power. And again, press home button and on / off switch, till it switches off. Then press the on / off button, till the Apple logo comes back, then release the button. It can take up to a minute, before the screen comes on.
Testimonial: "On pressing on/off button, the ipad switches off. but when you switch on the logo appears again and stays on.why?"
