Unable to log in to Jw.org with iPhone 4. Message repeats make sure caps key not locked on but cap key is NOT enabled .User name and password are approved.
SOURCE: CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature'
where if you hit CAPS LOCK and Shift at the same time, everything works
backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
SOURCE: iphone 8G forgotten password to unlock phone
The only way to bypass it is to put it into recovery mode. You can do this by turning it off and then holding the home button down then plugging it into the computer with itunes. The one you sync with. The phone will be in recovery mode, start iTunes and then you will be prompted to restore your phone. If you need further assistance, please ask.
SOURCE: I cannot send mail from
1- Delete the email account from your phone and re-enter it.
2- Passwords are normally case-sensitive, make sure you are using the correct characters.
3- Log into your email account from a computer and confirm your password is correct and works.
Change your password at your computer, log in and make sure the new password works, then start with step 1 above.
