Televison & Video Logo
Mustafa Mousse Posted on Oct 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Helllo, wanted to know how to get out of hotel mode
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 23, 2015
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987205
Points
237762
Refer its user manual for details. Electro help
Gary LiBritz
Level 2:
Champion:
  • Expert 209 Answers
  • Posted on Nov 26, 2014
Gary LiBritz
Expert
Level 2:
Champion:
Answers
209
Questions
Helped
43088
Points
347
The following are for LG TVs: From your remote, push MENU button for 5 seconds then type 1105 and press OK. You should now have a special menu displayed where you can modify the settings or disable hotel mode. Use the same procedure to go back and modify or enable hotel mode.
  • Christie Scott
    Christie Scott Mar 23, 2015
    I did the 1105.. the menu did not pop up. Its blk n white snow right now on analog
  • Christie Scott
    Helpppp
Remove (not disable) Hotel Mode
Open up the menu and do a factory reset. This will make it a normal TV again.
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
How do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
LED Hotel Mode key?
You have to enter its service mode option to turn ON of OFF and Adjust the Hotel mode options. If you wish to get more details about how to enter hotel mode, and make necessary adjustments, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timslide option. Never forget to EXIT service mode, after you've done all necessary adjustments.
Hotel mode setting key for TV
Don't know if you've sorted this by now or not but I found this PDF online. It tells you how to put the TV into public mode. Hope this helps 3_29_2014_10_44_37_pm.png
Sanyo tv in hotel mode
Possible only with buttons on some models to do this---usually the hotel remote is needed for this function for clear reasons--they did not want people to switch the set to this in the hotel.
2answers
Remove hotel lock
You have to get into its Service Menu option to unlock Hotel Mode. Contact any service technician. They only can do it, as entering into service mode, and adjust data values there; without any knowledge about it; might make the TV irreparable.
4helpful
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
