I have a Kodak Pixpro FZ51. I used it for the first time today and was taking what I thought were pictures but it turns out they are very short videos that I want as pictures. How can I fix this pleas
I was taking some shots today that I thought were pictures but they turned out to be VERY short videos of one scene. How can I make then pictures instead please
To remove the battery from your Kodak Pixpro AZ528 camera, follow these steps:
Turn off the camera and remove any cords or cables that are attached to it.
Locate the battery compartment cover on the bottom of the camera. It is typically marked with a battery icon.
Slide the battery compartment cover open. It may be held in place with a small latch or tab that you will need to release before you can open the cover.
Carefully remove the battery from the battery compartment. It may be held in place by a small latch or spring. Be sure to grip the battery firmly to avoid dropping it.
Close the battery compartment cover and make sure it is securely latched.
If you have any trouble removing the battery or if the battery compartment cover is stuck, you may want to consult the Kodak Pixpro AZ528 user manual for more detailed instructions.
This sometimes indicates that the exposure is correct for the distance of the subject. Remember that the flash on your camera is really only effective up to 3 - 4 meters
hi, go into menu and find delete all, this will delete all photos and videos, you can also type Kodak pixpro fz41 manual in google and download the manual, don't forget you can also bye a new memory card try and get one with a bigger memory than the one in the camera, hope this helps you.
I'm affrays your battery is gone. You could try to measure the voltage it is still giving with a multi meter, but I think it will be at least 1,7 volts less than what is printed on the battery. This means at least one cell in the battery is dead. I can't believe the contacts are dirty or oxidised, because the camera is too young. But if the contacts are not clean, try cleaning them with a dry cloth. If you should buy a new battery, make it a habit to charge it at least every couple of months, even if you only use it once a year. A battery is better off when charged and discharged now and then, then when you keep ik laying in a drawer.
