If I want to change value of inclination with any program also gives me a personalized video message Incline E2 . I also tried the factory reset and after conducting the tatatura the maximum speed I get the message Err Incline E2 . What could it be?
You problem was a stuck relay on the MCB. I have no idea why people give such awful advice on here.
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
SOURCE: treadmill will incline but not stay up. incline # stays after bed lowers
incline Motor is not working it can be a few different things.
1) may not be any signal from the console which could be a damaged cable(tight the flexible cable from keypanel vs display board)
2) Tight the connector from display board vs lower board ( main motor controller board the console itself has failed.
3) The motor control board may have failed from a worn treadmill belt and deck measure 120VAC input for the board
5) the motor may have burnt out Test try to measure 120VAC.
6) potentiometer geared to the motor adjust it so the console knows what height the incline is at.
7) the gearing can slip, giving the console false information which can cause chassis damage.
Now see the block diagaram that I did , for person like you, for to know how the main motor board has aprox 90% of functions of any treadmills. sincerely. Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: error message and no incline on my sole f63
1) Run the software calibration for diagnose, and troubleshooting and fix it.
2) lube the gear and shift from elevation motor
3) adjust pot from elevation motor
4) tight the wires connector
5) Test the elevation motor for defective, measure the input voltage see my personal TIPS.
God bless you
SOURCE: Sole F63 Treadmill Incline Error
I finally got back to my treadmill. I raised the deck and lubricated the tread. Then started it up and it went to ground as it should. Then ran calibration and it appears to be working again. No idea why raising the deck caused the machine to be able to go down again. Now I have to reset the speed sensor as I have it a little too close and it ticks occasionally while jogging.
