Apple iPad (16 GB) WiFi Tablet PC Logo
A
Anonymous Posted on Oct 20, 2014
How to hard reset ipad air to recognise another apple id
Changing apple id with hard reset
robert_welsh
Level 2:
  • Expert 85 Answers
  • Posted on Nov 25, 2014
robert_welsh
Expert
Level 2:
Answers
85
Questions
Helped
13198
Points
138
Go to Settings... / General
At the bottom of the list is Reset
You can do a full reset from there.
2 Related Answers
Jim Thomson
  • 1099 Answers
  • Posted on Feb 06, 2012
SOURCE: how to creat Apple ID for Ipade 2 16 gb
Go to https://appleid.apple.com/cgi-bin/WebObjects/MyAppleId.woa/
tbenko
  • 24 Answers
  • Posted on May 12, 2014
SOURCE: How do I unfreeze my Apple ipad air ?
It's actually very easy, once you know how to do it. Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom).
Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Apple ID and password help. My deceased husband set up the password and ID and I am locked out of my IPad. It asked for the original
Try hooking your iPad up to iTunes on your computer and perform a factory reset, changing the username and password.
How do I reset my password as my ipad has locked its self
if you know the email address just go to www.apple.com and you can reset there
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
How do I reset my Apple ID and password on my apple iPad Air without boot disc or iCloud password
Follow these steps to reset your forgotten Apple ID password: https://support.apple.com/zh-cn/HT5787
How can I remove a previous owners Apple ID from an iPad?
You need to either connect the iPad to iTunes and select "set up as new iPad" or you could also reset your iPad by opening settings/general/reset and choose "reset all content and setings". Both ways will delete all apps and you have to purchase or reinstall them.
How to reset my apple ID on my I pad
This needs to be reset by the Apple ID that first setup the Ipad. If you don't have that - you can take the Ipad to an Apple Authorized Service Center - along WITH a receipt or proof that you own the Ipad - and they can reset the device for you.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
