A
Anonymous Posted on Oct 20, 2014
Xerox 7345 009 343 error code
When swith on the machine the error 009 343
NICK FIRTH
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Xerox Expert 129 Answers
  • Posted on Sep 23, 2015
NICK FIRTH
Xerox Expert
Level 2:
Passionate:
Answers
129
Questions
0
Helped
110462
Points
234
The error signifies a problem with the 2nd btr retract position. Check the life remaining on the 2nd btr, also clean the 2nd btr retract sensor, and inspect sensor and gears for damage.
Dave Smith
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Xerox Expert 142 Answers
  • Posted on Apr 02, 2015
 Dave Smith
Xerox Expert
Level 2:
Scholar:
Cheetah:
Answers
142
Questions
Helped
67445
Points
230
Check out the Xerox.com website for more upto date information.
.Good luck.
1 Related Answer
Anonymous
  • Posted on Jan 11, 2010
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Xerox D95 error code 077-313.
Try disabling it.
4112 / D95 families - Fault Code 077-313 : Multi-Feed Sensing Problems. First ... You have the choice to disable the Multi Feed Sensing feature on the machine if you fail to repair the problem or if you have a hard time sourcing the sensor or the board. The NVM Setting code is: 742-268.
4112 / D95 families - Fault Code 077-313 - The Parts Drop
The Parts Drop https://www.partsdrop.com > index.php > 4112-4127-d9...
Fault Code 077-313: Oversize High Capacity Feeder Fault
Xerox https://www.support.xerox.com > en-us > article
Sep 21, 2015 - Fault Code 077-313: Oversize High Capacity Feeder Fault · Try these solutions · Did this help?
Error Code Xerox 4112 Error 077-313
Copytechnet https://www.copytechnet.com > ... > Xerox
Sep 6, 2019 - Cause: Multi Sheet Check Sensor Actuator loose due to torsion spring disconnected from the arm. Due to improper removal of paper jam at Registration Roll.
Jamming Error 077-313 and error 075 - 211
Nov 30, 2016
Xerox 4127 cp error 077-313
Sep 24, 2016
Error Code xerox 700 077-311
Jan 11, 2021
More results from www.copytechnet.com
Fuji Xerox ApeosPort-IV C4430. It has 116-331 fault code error. Any assistance to remove and get it done??
Question edited for clarity.
Power Cycle it.
Fault Code 116-331
Jan 19, 2021 - Power off/on the printer. For details, refer Power Off the Printer Using the Power Switch. Wait Two Minutes and Then Power On the Printer.
Missing: C4430 ‎' Show results with: C4430
Thread: Error 116-331
Jan 20, 2012 - Hi, 1. Check and reset all connectors on ESS PWB and HDD. 2. Press and hold the 4, the Stop, and the Power Save buttons on the Control Panel ...
Xerox workcenter 5225 show error code 116-331
Sep 10, 2019
Dead Machine 242 code 116-331
Sep 10, 2019
WC 6515 Error 116-331
Jun 6, 2019
xerox workcentre 5225 116.331 error code
Sep 6, 2012
More results from www.copytechnet.com Missing: C4430 ‎' Show results with: C4430
Need urgent help with Error Code 116-331! It's a PrimeLink ...
Reddit https://www.reddit.com > Xerox > comments > need_u...
Nov 26, 2022 - 116-331 is usually just a corrupted job. Power off the machine using the button behind the front door. (not the button on top). Press and hold # ...
1helpful
2answers
Model 560. What does error code 062-395 indicate?
http://www.manuals365.com/swf/fuji+xerox/ag-c560p_c550p.html?page=207
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Our xerox dc12 gives a message system fault turn power off the swith is on the right side pause and turn back on Code 9-357
The error 9-357 normally refers to a toner issue.
This normally refers to a color/Black toner problem. Probably there is low toner sensor defect.
Check for the ink in the cartridges as well but before that try to vacuum and clean the toner dispenser. You must vacuum whole path which is used to transport the toner to developer unit.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
