Anycom HCC-500 Bluetooth Car-Kit Logo
Eugene Lucas Posted on Oct 22, 2014
I need a car power adapter for the product.
12 volt power adapter stopped working and I need replacement.
Jessica Bixby
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 03, 2014
Jessica Bixby
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
515
Points
7
Electronic stores, Walmart, & even pharmacies now carry various adapters for products. You may want to check there.
Steven Poniewaz
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 28, 2014
Steven Poniewaz
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
507
Points
Walmart should sell car power adapters, or even radioshack, or any auto parts store
Testimonial: "I went to Radio Shack previously and was told to contact the manufacturer"
1helpful
How can i hook up a car stereo in the garage without using a car battery, and get the same juice as far as wattage and power???
Wire a 12 volt AC adapter to it. Connect the power to the positive wire, & the ground to the negative wire. If it's a low power unit a 1 amp adapter will work. If it's a high powered unit you might need a 12 volt 5-10 amp adapter designed for monitors, TVs, monitors, & some laptops. Beware some laptop AC adapters can be 16-36 volts. Make sure you use a 12 volt one, & know which wire is positive, or you'll burn it out.
2helpful
Need to find replacement padapter no. JoD-41U-02 for pro-2018. Can't locate one. Do you know where I can buy one.
The exact replacement power adapter for your scanner is out of production. Power requirement for the PRO-2018 is 12 volts with a minimum of 300 mA. Radio Shack has a universal power supply that will work, or you can pick one up on eBay for under $20, including shipment. You can also pick up a voltage-specific power adapter on eBay or elsewhere, but you may have to change the DC plug to match your scanner.
Bill B
1helpful
I purchased a used etx90ec. Two of the battery terminals are moderately corroded. The lights on the control do not come on and it doesn't work.
If you can clean up the battery terminals with sandpaper, then you will need to try an outside power source.
Buy either the 110 volt adapter or BETTER but a 12 volt power pack at Wal Mart (the kind you use to start a car) make sure it has a 12 volt cigarette lighter style plug.
You can buy either the 12 volt power cable or tthe 110 volt adapter from www.scopestuff.com. I never use the internal batteries, always a 12 volt power pack. The ETX likes steady 12 volt current.
If it does not work with the outside power source then something is burned out on the main board. You will need to return it to Meade for repairs. Here are several links you need.
http://www.meade.com/support/index.html
http://scopestuff.com/ss_cig1.htm the 12 volt cable
7helpful
2answers
2002 Acura TL Type-S Radio Fuse Blown??
Passenger Side fuse box, fuse number 9 neets to be replaced
Bad power adapter for x2 gen monitor
http://www.digidave.co.uk/jshop/product.php?xProd=574&ref=adwords&gclid=CO7-yI6E5pwCFZ0U4wodaELMGg
Looks like that could be what you are looking for.
Nick
4helpful
2answers
I have a sharper image midi and the red light (cleaning overdue)stays on even after cleaning? Will it still work with the light on? My real question how to fix it
Same problem : after cleaning thoroughly inside by removing the Front& Rear Plastic grid and the stainless blades, I also cleaned the 2wires (very softly and carrefully, not to break them), but the Redlight goes on after only few minutes :
Here is my Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no more Red light. Maybe it will work for you. I also found this other bit of information. Since then I have discovered a lot of information on the midi. Here is some more reading material that might interest you.
Could be a blade replacement needed but Sharper Image2.gifrecalled the product. Since it was proven in court that it wasn'teffectively cleaning the air by Consumer Reports as well as EPA data. As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commissionis going to be making a decision on ionizers at the end of year sincethere are hazards in the air from using the devices. It could be thationizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it. The next step to do if you can't get it to work is to file a report with the company.
The Ionic Breeze would work for a short time after cleaning and the bluelight would start flashing again. We checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So we went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so we don't use it anymore.
Best wishes. Hope this helps you. If not please leave me a comment and I will do some more research.
1helpful
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Top Anycom Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
