Washing Machines Logo
Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE washer will not run a full cycle. It fills up non stop, while at the same time its draining. It was running the cycle and would get stuck on the rinse/spin cycle. But now the knob doesn't even move when on.
Anonymous
Level 3:
President:
  • Master 1,185 Answers
  • Posted on Jul 05, 2009
Anonymous
Master
Level 3:
President:
Answers
1185
Questions
Helped
385930
Points
3708
One very slim chance is that the waste water hose does not have an air break in it
The pipe is supposed to be placed into a drain which allows a flow of air to the pipe out of which the water is being pumped
If there is not an air break then the mchine can set up a syphon action which will not allow the unit to fill to the right levels
Quick check is to dump the oulet hose into a sink and run the machine , be sure to secure the pipe in case it slips out and also that the sink can empty fast enough for the water being pumped into it by the washer .
If you are saying that the machine wont stop filling try turning the water off at the fawcet
1helpful
Ge older model dishwasher, filled with water , but wont run its cycle, I have motor and cycle noise
If you have what looks like a white disk in the center, you need to clean around the outside edge of the disk and put a thin layer of good high temp sillicone around it and wait a full day before using it.If the outside edge of the disk leaks the washer will fill and run but will not drain.
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
2answers
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
GE profile wpre6150k2wt washer never fills up, water runs in and immediately drains and the cycle never stops. Status timer on front just has spinning lights
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
1helpful
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Washer will not fill in rinse cycle.
hi, When the washer acts up in the rinse cycle, will it try and fill and then the water starts going out the drain hose? If this is the case, the drain hose is either needs to be raised to be as high as the top of the washer or, it needs to have a loose fitting where it goes into the drain pipe so it can have air **** back into the drain hose after it releases the wash water.
i know this is a lot of info that might not even be the answer but, I am giving you the most common fix. Please let me know if I have answered your question or let me know if I can assist you further.
If this does not seem to be the answer, maybe I need clarification.
Vic
1helpful
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
1helpful
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
7helpful
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
1helpful
2answers
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
