Purchased jumbo universal remote, but do not have a manuel to show me how to program it.
SOURCE: need programming codes for Innovage Jumbo Remote
here is your manual. good luck.
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
SOURCE: I would like the codes for the Innovage Jumbo
You can have the Innovage Jumbo Universal Remote search through its codes to find the proper one automatically. These are the steps to program it for a TV:
To have the remote try each TV code it knows one at a time, follow these steps:
To program the remote for your VCR, repeat this process starting with
turning the VCR on, then follow the steps substituting the VCR button
for the TV button.
I hope that helps.
SOURCE: I recently purchased an innovage jumbo universal
Start by turning on the TV, press and release the TV button,the light will flash once, press and hold CODE SEARCH the light will remain on, press and release the POWER button,the light will flash while searching for the code,once the TV turns off, press ENTER or OK , the remote is now programed...hope this was helpful...
SOURCE: User guide for innovage jumbo remote with coloured
http://www.jumbouniversalremote.net/
Start by turning on the device that you want to program.
(1) Press & release the device button that you want to program, lets say "VCR" LED will flase once
(2) Press & hold the "CODE SEARCH" button until the LED stays on.
(3) Press and release the POWER button. Point the remote at the device.
(4)The LED will flash as the remote is searching for the code.
(5) As soon as the device turns off press and release the "ENTER" button.
The remote should NOW be programed.
Testimonial: "Thank you so much... Perfect, works great."
SOURCE: how to sync a innovage jumbo universal remote
Start by turning on the device that you want to program. (1) Press & release the device button that you want to program, lets say "VCR" LED will flase once (2) Press & hold the "CODE SEARCH" button until the LED stays on. (3) Press and release the POWER button. Point the remote at the device. (4)The LED will flash as the remote is searching for the code. (5) As soon as the device turns off press and release the "ENTER" button. The remote should NOW be programed.
