LG 50PX4DR 50 in. Plasma TV Logo
c
chrissy jenkins Posted on Oct 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I clear the hard drive to the dvr so I can get it to record again.
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Oct 28, 2014
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004349
Points
237762
You have to format it. Refer its user manual for details. Electro help
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
Motorola DCT6200 DVR Recorder does not play stored video when cable signal is loss
no hard drive in the dct6200 it is not a digital video recorder (dvr)
it can do video on demand which kinda streams to you and can pause and rewind and such.... however, it will not pause live tv or record for later playback...
hope that clears some confusion
Need to recover data from DirecTV R15 DVR receiver hard drive
First, sorry for the delay in respoding to your post. I did notice that you had a prior question about the Power Supply on an R15 DVR. Does the unit have a manufacture code of 500(found on the right hand front Flip Door of the DVR)? If so, I might be able to help you in repairing the Power Supply. As far as I know, getting your DVR up and running again is the only way to watch your previously recorded programs. As far as retreiving programs from your old Hard Drive via other methods, I probably won't be able to help you there. When I had both of my identical DVR 15 500's apart for a parts swap to diagnos a failed Phototransistor(infra-red sensor for the remote control), I also tried to swap out the Hard Drives. This is what I found: When you swap a Hard Drive into another DVR, it won't play any of the programs previously recorded. However, if you record new programs on the swapped Hard Drive then they will be playable on this current setup. Now, if you swap the Hard Drive back to the original DVR it came out of, the programs will once again be accessible except for any that you might have recorded while the Hard Drive was in the other DVR. So, in conclusion, when programs are recorded on a particular DVR, it is encoded electronically to play back only in that DVR via communication from the Motherboard and the Hard Drive. I know, it sucks, but that is why I was asking if you are pretty sure the Power Supply is at fault. If so, I received info from this forum on how to fix the issue. Also, if the attempt fails, Ebay has some previously owned DVR's for sale and maybe you can get one for spare parts. Remember, the Power Board and Front Display Control Panel are the only interchangeable parts IF you want to view the programs on your DVR's Hard Drive. Let me know what your DVR does when you plug it in. That will go far in further diagnostics of your DVR.
Hi we have inherited a Pioneer DVD Recorder DVR -530H. I have no instructions - the foxtel guys has hooked it all up to the TV however I cant work out how to clear all the recordings that are stored on the...
  1. You must be in the Disc Navigator (HDD)
  2. Highlight the title you want to erase.
  3. Select 'Erase' from the command menu panel.
  4. Select 'Yes' to confirm or 'No' to cancel, then press ENTER.
  • You can also Highlight the title you want to erase, press clear on the remote, and press ENTER.
Here is your manual: http://www.pioneer.com.sg/storefront/manual/DVR-530H.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I want to record to a external hard drive in order to take to Ira
If you have a dish network system as listed in post a DVR 625 this is NOT possible, it will only work with VIP series Dish Network recivers. and they must be used on teh same model reciever such as Vip 722, tranfer to EXT HD then Watch on another 722!
DVR not playing.
Try this: Press the power button and hold it for about ten seconds and let the system reboot. Try to use the dvr again. If that was unsucessful try unplugging the receiver from the wall outlet for approxiamately 30 seconds and repower the systen and try again.
If these have not worked You can press menu-6-1-3 and view the system info screen. Go to the details options and select it. Once the details screen loads arrow all the way down until you see the values of which value 9 is the last one. If value 7 is not 4 you need the unit replaced. If all the above did not work the unit will still need replacing as the hard drive has locked up.
Dish has a new receiver called a 222k which has an expansion USB port that will allow you to use an external hard drive to use as the dvr as the 222k is not a DVR unit; it is a HD dual tuner. The external hard drive offers many advantages such as being able to take your recordings on the road, ability to keep recordings if the receiver fails, etc. Another awesome device they have also is called a sling box which will allow remote viewing of your Satellite from a remote location over a laptop, PDA, or cell phone.
I hope this helps you and thanks for using Fix Ya.
4helpful
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Clearing everything
A DVR has a small computer built in. When you run the clear everything option, this feature reinitialized the computer Hard Disk Drive doing a limited format. A format of a Hard Drive is always a slow process which normally takes 45 minutes to 1.5 hours on a 40 GB drive. Yours will actually take longer since it is larger (250 GB for 200 hours recording time), so I wouldn't panic yet. As long as you have a flashing red light on the box, it IS still formatting. If it goes beyond 8 hours, I would suspect you might have a problem or have been having some problem before (that motivated you to use clear everything).If, after 8 hours, it hasn't completed the format (red light flashing) then I would pull the cover on your DVR and pull and reseat the EIDE cable on the Hard Drive. Then restart again. Dirty contacts can cause this problem as well. Put the cover back on, do a hard restart and let it run again. If after another 8 hours, the problem still persists, then you may be experiencing read/write data errors on the drive. A failed or failing Hard Drive is most likely the culprit and it will have to be replaced. www.weaknees.com sells pre formatted and loaded Tivo Hard drives. If this is a Western Digital Drive, I would replace it with a Maxtor from them since the Maxtor are a special design just for DVR's.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
