Ariens model 915111. Blades will not engage. Using a light voltage device. I placed the probe inside the socket which was connected to the pto clutch and it lit up. Can you tell me what part needs replaced. Blades will not engage.
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
SOURCE: PTO does not engage
if your belt was tight when you finished installing it and all the pulleys that it went around are free turning by hand and lining up reasonably well you should be ok.
to the clutch
are you good with a volt meter 12volts dc?
Find your connector close to the clutch
unhook it from the clutch
take your volt meter and engage your red knob (Have the key on and parking brake applied)check your voltage to the connector
Do you have 12volts dc?if so your clutch should work if not you need to trace the wire back to the red knob
check all of your fuses check all of your safety switches.
Or have a 12 volt source (a battery )and hook it briefly to the connector you found directly to the clutch connector pos. and neg. from your battery you should hear an audible CLICK if so your clutch is good if not you are losing 12 volts back toward the red knob
this is the best way to check the clutch while it is still on the machine.
if its the bad clutch get your wallet out they are expensive.
to remove it unlosen center bolt on the crankshaft
remove or move belt guards out of the way and whole assembly should slide right off, note any shims and spacers that may come down with it and their locations
put back the same way it came off and tighten center bolt to 55 ft.lbs.
goodluck
SOURCE: Blades won't engage. OK-I need a pto clutch
A switch should only be about $25. Before you spring for a new PTO assembly, take your switch out and take it to a shop and have it tested. I may just be a bad switch. Don't bother taking it to Sears though. Take it to a shop that works on Husqvarna and/or Poulan Pro. (Both basically same as Craftsman). DO take the model number from under the seat with you.
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
SOURCE: PTO will not engage blades on riding mower. The
Using a test light or volt meter, check to see if you are getting a full 12 volts at the connector where the PTO plugs in. If no voltage present, locate the fuse for the PTO and check it, also check the PTO switch to see if it is working. You can turn on the ignition switch to the run position, don't start the engine, and turn the PTO switch on and off several times listening for a clicking sound. If you hear it clicking, have someone sit in the seat and start up the engine, while it is running, observe the PTO clutch and see if it spins when turned on and if the belt turns with it. If none of this works, post a follow up and include your Craftsman Model number. I will look it up and see if I can find anything else we might be missing
