No battery or battery is bad. Check that the battery is even plugged in to the socket.
Testimonial: "I have only had it 3months"
Makes no diff. ou could have bughtit an hour ago, a battery is a batery, good bad, it's still a batter. If it's plugged into the socket and charging when you plug the cord to the wall, it will charge the battery. If the batery is not accepting the charge and the unigoes off when you unplug from the wall, the battery OR charger is BAD.
Depending on how old it is and how often you use it,might need a new battery. They stop taking a charge after awhile .
Testimonial: "where is the battery located"
