I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 min max. After first go round when you punch start again it goes foe apps 10 min.
SOURCE: Maytag Dryer will not start again
Agreed --- the motor is overheating.But the question is --why? If the motor is old 8-10 years, then that is expected.
SOURCE: Dryer runs ok. igniter
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
