SOURCE: I have this RCA Universal remote (RCU410WMS) and I
RCA's site list codes 25 and 006 for Magnavox cable boxes. Maybe one of these will work for the converter. The RCA site has a link so you can look up codes. Click on "find your remote control codes here" and pick your model number, then the type of device you want to control. If the codes I gave don't work, maybe try some of the other brands of cable box codes. You might find one that will work.
SOURCE: Program Magnavox Converter Box into my Directv Remote
Hi
No But, If you have Directv then you don't need a converter box.
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
ineed manual code for rca universal remote for toshiba tv
SOURCE: Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
SOURCE: Cant get program codes to work on AKIA tv with rca converter box
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai was 11676. Take care...
