Kitchen Appliances - Others Logo
Phyllis Bushers Posted on Oct 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lid melted into the grease on my FryDaddy. Is it safe to cook in?
The grease was discarded and frydaddy cleaned with hot soapy water. Will it put toxins in food cooked in future?
graybeard32301
Level 3:
  • Master 382 Answers
  • Posted on Oct 30, 2014
graybeard32301
Master
Level 3:
Answers
382
Questions
0
Helped
128255
Points
1328
It is probably safe. But why not load up one time with new oil and cook a load of french fries, and then throw the oil and fries away, just to make sure.
2answers
I have a Viking pro model oven VGIC3064BSS that doesn't light fully
Viking Gas Range Burners Won't Light? Here's What To Do... We'll discuss how to properly check the power sources and igniter when your Viking gas range burners won't light. We'll also provide a step-by-step guide illustrating how to clean Viking range burners with the right methods and materials.
Check For Power And Loose Connections
Are your Viking stove burners not igniting on demand? This may be more of a power issue and not a range malfunction. Even though you have a gas range, electricity is still required to ignite the burner. Here's how to check your stove's electrical sources to make sure they're functioning properly:
  • Make sure the stove is correctly plugged into a functioning outlet.
  • Check the stove's circuit breaker or fuse in your home's circuit breaker or fuse box. Reposition a tripped breaker or replace a blown fuse.
  • Refrain from using an extension cord to power your range. Most cords can't safely transmit the electricity required to power the stove.
How To Clean Viking Range Burners
Despite our best efforts, cooking spills and accidents can leave range burners compromised. Liquids, grease, and grime that go unnoticed during a hasty post-dinner cleaning can impair range components, resulting in burners that won't light.
This step-by-step guide provides Viking range cleaning tips that clean your burners and other stove components safely and effectively:
Grates:
Remove the grates and soak them in a sink of hot, soapy water for 15-20 minutes. For stubborn stains, add ammonia to the soaking liquid or scrub with Soft Scrub cleanser. Rinse with hot, soapy water and dry completely before replacing.
Burner Caps:
  1. Remove the caps by lifting straight upward.
  2. Scrub with hot, soapy water and a non-abrasive pad, using Soft Scrub cleanser for tougher stains.
  3. For persistent staining, place burner caps outside on a sheet of newspaper. Spray with Easy-Off Fume Free Max oven cleaner and allow to sit for 1-2 hours.
  4. Rinse with hot, soapy water.
  5. Allow caps to dry completely before replacing.
Burner Heads:
  1. Remove burner heads by lifting gently upward.
  2. Combine Bar Keeper's Friend and water to make a paste.
  3. Apply the paste to the burner head and leave for 30 minutes, resting on a clean towel.
  4. Scrub the paste into the burner head with a non-abrasive pad to remove stains.
  5. Rinse with hot, soapy water.
  6. Allow to dry completely.
Cooks essential #99770 2 art Pressure cooker lid when manual closed is not exactly even
The valves on the lid are "floating" valves, that means they will not sit firmly on the lid. However, food and gunk can get stuck in these valves. Remove it, soak it in hot soapy water, clean the inside with a toothpick and also clean the pipe on the lid that holds the weight. Your pressure cooker should be as good as new!
Sep 20, 2015 • Home
Lid melted in fry daddy. is it safe to use for human consumption
shouldn't if you cleaned it. Just make sure there is no globs of plastic stuck anywhere
Need an instruction manual for the Presto Fry Daddy..where can I get one and how much is it?
Your Instructions for the Presto 05420 FryDaddy Electric Deep Fryer can be downloaded from the following site:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000008244.pdf
Thank you for using FixYa!
The clean light came on and I cannot find my manual to find out how to clen it. Plaeas help
Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Lift up the reservoir cover. Remove and discard the paper filter and ground coffee. The filter basket can be washed in warm, soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after use. Do not put any water in the unit once the filter basket has been removed. Wipe the area under the filter basket with a damp cloth. Remove the carafe from the heating plate. Discard any remaining coffee. The carafe and lid can be washed in warm, soapy water and rinsed thoroughly, or placed in a dishwasher. The carafe and carafe lid should be placed on the upper rack only. Do not use any scouring agents or harsh cleansers on any part of the coffeemaker. Never immerse base unit in water or other liquid. To clean base, simply wipe with a clean, damp cloth and dry before storing. Fingerprints and other blemishes on the stainless steel housing can be washed off with soap and water or a nonabrasive cleaning solution. Wipe warming plate with a clean, damp cloth. Never use rough, abrasive materials or cleansers to clean the warming plate. Do not dry the inside of the water reservoir with a cloth, as lint may remain.
You can print the manual on this link:
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
What should I clean my Brinkman smoker with -- is it safe to use SOS pads on the racks (where you put the meat)? How about the inside of the cover - should this be cleaned or left alone? If should be...
If your racks are the chrome ones, yes, WET SOS pads will work. So will the green Scotchbrite pads and a degreasing detergent. As for the lid, the safe way to go is a degreaser and HOT water with a non abrasive rag. If you have a good enamel paint on it, then oven cleaner works as well. Just make sure you rinse it really, really, well with hot soapy water after cleaning it with oven cleaner. (This is how I clean mine).
Frydaddy plastic lid melted. What diameter glass lid might I use to replace it?
I don't have a glass solution, but if you frydaddy is like mine, it has a 7.25 inch dia lid. For about $2 the "Glad Big Bowl" (6 cup size) plastic containers have a lid that fits pretty well.
1helpful
1helpful
I need to replace frydaddy cover
For a replacement cover call Presto customer service at 800-877-0441. Have the complete model number found on the bottem of the unit.
I starts with 054xxxx. Orders are taken with credit cards.
Cleaning
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Top Presto Kitchen Appliances - Others Experts
Paul Bade
john h
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
