I sent a email which was too big and is now blocking all mail in and out as it tries to send
This is one way I've found to delete an email stuck in the outbox (which is what it "sounds like" you are asking...)
1. change ya smtp settings so the message defo wont send!
2. send a test email to anyone
3. it will attempt to send but oversiously fail...
4. hopefully the outbox should be listed with 1 message waiting to go out...
5. if not, try going into the Activity Window and canceling the send command, that should show it up...
6. click the Outbox and the will be one message listed...
7. goto View -> then Show Favourites Bar
8. you should see a favourites bar appear...
9. simply drop and drag the Outbox into your favourites bar...
10. if you restart ur laptop or close mail and then the Outbox has disappeard, simply click the Outbox in you favourites tab and woop woop it should appear in the Side Bar
SOURCE: I cannot get my roadrunner mail to work on my
Hi. Try this torubleshoothig steps. Delete the mail account and start over with the defaults ... Or start here => For the SMTP server, use host "smtp-server.nc.rr.com", change the default port from 587 to port 25 (in coming pop server should be 110 by default). If you have mail in your Outbox you will get a error message that you cannot connect, delete all mail in Outbox, now try sending yourself mail.
