All lines crumbled apart and I can't tell where the new ones should go. One line from the fuel tank (obviously), then there are two port on the primer bulb, and two on the carb. I need a fuel diagram. Thanks
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
The smaller diameter tubing goes to the primer bulb into the tank, the larger from the tank to the carburator. The size of the nipple that the line fits on should also help in making this determination. Be sure to drain tank and reattach the filter that is probably laying in the tank. Thread that hose up through the filler hole to do this. I hope this helps.
When cleaning small engine carburators,o-rings and any plastic parts do not use any carb cleaner products.The cleaners when dry, attend to leave some residue in the cylinder wall of the carburator.I find that ammonia is a great cleaning solution,You can even clean any rubber or plastic parts without damaging them.It evaporates,there for it leaves no sign rsidue.Also,very inexpensive to buy at the dollar store.
