I accidentally wiped memory of phone how can I retrieve it I restored it to factory fault
I assume your HTC phone is running Google Android. And here is a guide about how to recover Android device data, it will help you retrieve the contacts and data. How to recover lost deleted Android Data
SOURCE: i forgot my mobile password
YOU MUST NEED TO READ YOUR USER MANUAL FOR YOUR MOBILE PHONE. THE SOLUTION MUST BE IN IT TO RESET YOUR PASSCODE.
IF YOU CAN DO SO YOU MUST HAVE TO GO TO THE MOBILE SERVICE STATION TO SOLVE THE PORBLM.
PLS. RATE MY SOLUTION
HAVE A NICE DAY
KETAN
SOURCE: RESTORE AFTER ACCIDENTAL FORMAT
try data recovery doctor if it doent work u cant bring back the data
SOURCE: Nokia N81 Phone memory problems.
To start, please note 34KB isn't much space at all. That phone has a minimum of 12 megabytes and a maximum of 8 gigabtyes depending on when you got your phone.
But just for size comparison, 34 kilobytes = 0.033203125 megabytes so you have plenty of space, those kilobytes mean nothing.
I don't personally own a Nokia phone, but from what I hear, all of
their phones have software on them called Lifeblog, it stores all of
your photos taken, and all of the calls you have made on your phone and
arranges them in a time line, this ends up taking up a lot of space and is a cause for many of the memory related problems.
Possible Solutions:
First:
Backup anything you want to keep with Nokia PC Suite
Then:
Reset your phone to factory default by either typing *#7370#
OR
Holding down 3 * green whilst switching it on.
Be wary when restoring any backup you have, being this will restore anything that your Lifeblog contains, reverting the problem.
And a final solution
Download "Y" browser here
Install it on your phone via your Nokia PC Suite.
Launch the YBrowser application (probably from new folder called DrJukka.com):
Locate the C: drive and open it:
Locate the Data folder:
Locate the Lifeblog folder:
Select Options, File and then Delete
Once the folder is deleted launch Lifeblog and select Update Timeline.
Hope one if not all of these helped =)
SOURCE: how to recover Nokia 5130 deleted mobile contact data?
trun it off then wait for 20 minutes and it workes
SOURCE: How to retreive data from Samsung Galaxy Pocket Cell Phone
well ,bro ! Take it easy, Firdt of all, do you have google account or facebook, or other backup apps? you can reocver data from google account and the facebook account can save your photos in its server, so you can recover photos from them. Secondly ,you have installed PC companion of the Samsung phone to your computer, right? Thus ,you can check the PC companion, maybe you can find some backup from the application, which will make a backup for your phone when you connect the phone to the computer. Lastly, if you do not have any backup, you can recover photos by some recovery software, such Recuva, which just can recover 60% data.Anyway you can try to use other one is better, know more here: http://www.card-data-recovery.com/recover-photos-videos-from-samsung-galaxy.html
