Question about Apple iPad (16 GB) WiFi Tablet PC
Apple i-pad air boots up to a larger screen,the touch icons are hard to move.
  • Apple Master
  • 1,150 Answers
Hi Julie
If by larger screen, you mean Zoomed screen, it could be that you have turned on zoom in Settings / Accessability.
Also.... the iPad is "booted up" all the time. Generally all you are doing is Waking the iPad from sleep or screen in sleep mode.
To ReBoot your iPad (worth doing every month or so) First quit all Apps by double clicking round button and individually swipe each open App upward to shut the App down. When all apps are turned off, Hold the Top button & Round Button in together for about 5-10 seconds. This will shut the iPad down completely. When all off, Press the top button in for about 5 seconds. You will see the Apple logo while it ReBoots. This usually fixes any minor glitches etc in the Apps. If a particular App is giving problems, you can hold your finger down on it till the X shows in the LH Top of its icon. Click this and it will be wiped off your iPad. Then re download it for free through the App Store and check to see if problem has gone.
Hope this proves useful.
OJ
Posted on Nov 02, 2014
Testimonial: "Thank you were right it was on zoom setting screen, am going to take your advise and do a reboot. Very gratefully julie"
6ya staff
SOURCE:
Have echo and new apple i pad how do i install it to get wifi. i have 0 knowlwdge
Follow the small sheet of instructions that came with the ECHO.
if you want to hear music (and other audio) in stereo, attach a separate pair of stereo speakers to the 3.5 mm jack on the back of the ECHO (I'm assuming it has one like my Echo Dot does).
you may have to push the 3.5 mm plug in hard for it to connect to both stereo channels on the cable. If you only hear sound out of your left speaker, both channels aren't connecting. Disconnect and reconnect the 3.5 mm cable a few times, being sure to push it in hard. This will loosen up the jack so that the plug connects easier and correctly.
On your iPad, open the App Store by tapping its icon.
in the search box at the top, type Alexa.
From the list provided, click the Open button next to the icon for Amazon Alexa, and follow any instructions that may follow. The icon should appear on you iPad, most likely on the last screen of icons (assuming the you have more than one screen of icons). Sweep to the left until you get to the last screen of icons to see it. Then click on the icon to open the app. When the app opens, click on the "3 horizontal bar" icon in the upper left corner. A menu will drop down. Click Settings. Then, click SET UP A NEW DEVICE , and follow the instructions.
Nov 14, 2017 | Apple Tablets & eReaders
Reset ep121 asus tablet
http://www.technipages.com/how-to-soft-and-hard-reset-asus-eee-pad-transformer
Dec 04, 2015 | ASUS Eee Slate EP121 Touch
How do I capital letters on my apple air ipad key pad
In your Settings app, go to General-->Keyboard and make sure the "Enable Caps Lock" is on (green).
After Caps Lock is enabled, quickly touching the Caps key twice will lock it.
(Directions are for iOS 8)
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Feb 16, 2015 | Apple iPad Air
Keeps saying I am not connected to internet?
In the Settings app,
  • make sure the Airplane Mode is OFF;
  • check to make sure the WiFi indicates a currently available network name,
    • or choose an available network by touching WiFi and touching an available network from "CHOOSE A NETWORK"
      • (you must have a user name and password for one or more of those networks that have a lock icon);
  • Check to make sure that Cellular-->Cellular Data is ON if you have no available WiFi.
Feb 15, 2015 | Apple iPad Tablets & eReaders
How do I remove permanently Big fish casino app from my I pad
Bring up all your Apps icons on Ipad, then touch the Settings symbol and a pop-up box appears. Find the word Uninstall, usually has a rubbish bin icon. Then touch on Uninstall and the screen changes to uninstalling mode. swipe/scroll left or right until the Installed Apps appear. The Installed Apps are usually marked. Find your Big Fish app and touch it. A Delete confirmation message appears. Touch the Ok button to delete it.
Dec 28, 2014 | Tablets & eReaders
I cannot get my IPad to delete some icons on my iPad screen I no longer need
When removing those icons you are actually deleting the apps from your ipad. There are some apps built into you ipad and those cannot be deleted.
However you can move them out of sight to another screen.
Or create a folder icon and move them there if you do not use them often.
Mar 19, 2014 | Apple iPad Tablets & eReaders
Ipad 2 has a transparent line moving across screen
have you tried a hard ware reset?
turn off device, then hold the power button on top and the home key (make sure its not plugged in also)
keep Holding both keys... you will see the apple logo appear, and then flash off, and then it will restart again. If you keep holding the home key and the power key, it will continue in this loop. Holding it until it reboots once should be enough though, then just turn it on and let it boot normally.
Your settings and everything should remain the same, this just will reset the hardware on the device. I have had issues with my iPad 2 with games lately, mainly random crashing, when I do this hardware reset, it usually fixes my crashing issue for a while.
Once again the steps are:
Shut off device, make sure it is unplugged
Hold the Power button and home key, until the apple icon appears and then flashes off.
Let the device turn on normally, let go of home key and hold the power button till the apple icon appears, and let it boot up normally.
Test the application, this may or may not work. But its def worth a try.
Mar 07, 2014 | Apple iPad Tablets & eReaders
Hanging up
hard reset, press and hold both home and power button until device shuts off. then restart.
Jan 05, 2014 | Apple iPad (16 GB) WiFi Tablet PC
The pc star ok but it keep given me a white screen
It is possible that the problem in the slide card that beats screen located on the main board and the faults which also appear on-screen plasma appearance of a white image on the screen or the colors are without any data. Easy to verify the integrity of the slide card that beats the screen by pressing of Touch Pad or the left part of Keyboard to the East, including notes. When connecting to an external monitor with no emergence of data
Among these symptoms we see that it is clear that the device temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
Jul 14, 2010 | HP Pavilion tx1220us Tablet PC
Apple iPad (16 GB) WiFi Tablet PC Logo
105 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
