When charging charger flashes slowley but will not run sweeper even though it says fully charged
SOURCE: swivel sweeper battery is not charging
the problem is not repeat not with the batteries. i bought another sweeper from a local department store. when i got it home i put the new battery in the old sweeper, and it ran for about a minute. then i put the old battery in the new machine and it ran fine. so the problem is not the battery but somewhere betwee the battery pack and the brushes.
SOURCE: replacement battery for a Shark rechargeable sweeper
You can order a replacement battery by going to their website:
http://www.sharkvac.com/partsearch.aspx?CatID=cxmdqvOilfw%3d
You have to put in your model information to get the right battery.
SOURCE: Not holding charge
Ok, folks.. I just posted my own problem with the battery not holding it's charge..but, we fixed it ourselves.. take the motor loose from the canister , remove the filter and in the back are two contacts.they are two screws at the bottom one on each side... get out your pencil with a GOOD eraser and clean those contacts!..clean around them both and the contact (silver spot at the bottom) and you're good to go!!
SOURCE: Hi, this is our third Dyson DC-16.. the Trigger
How are you charging your battery? Every battery has a memory. If you dont let it die the first come times then charge to full the battery will assume 40% is 100%.
Testimonial: "Thank you for your solution, but we've had it at least a year.. it stays on charge when not in use.cleaned the connections.working better, not 100%.."
SOURCE: My dyson DC16 constantly shuts off even when
Hi its Darran at Dyson.
From your description of the problem, it sounds as though there is a problem with the battery.
Your DC16 will have been supplied with a 2 year guarantee. If it still within this period, please contact our Helpline on 0800 298 0298. However if your machine is no longer covered, a replacement battery can be purchased via our website at www.dyson.co.uk/store.
Kind regards
Darran
Dyson Customer Service
