Overcharged batteries used in A95. I put new Li ion batteries in my canon A95. Camera would not work after I did this. I took the batteries and tried checking them in a flashlight. When I turned the flashlight on, it flashed very bright and blew the bulb out. i think I fried my camera
Lin, I'm afraid you are right. The camera should work on 4 AA Alkaline or NiMH rechargeable batteries. They give about 1,5 V maximal. The Li iOn batteries, almost deliver 2 V each. 4 x 1,5 (6) or 4 x 2 (8) gives a difference of 2 V. that is almost 33% to much.
But before you panic, Please first check if the contacts in the camera are clean and shiny. You can clean them (if necessary) with a dry cloth or cotton swab. Don't use anything sharp in or close to a camera.
Then insert new alkaline or NiMH barrettes, as shown in the manual and switch it on.
If it still does not work, contact a Canon certified repair centre and tell them what you did with the batteries and ask them if the camera is worth repairing.
Success
SOURCE: Canon A95 gone dead
I ain't so lucky I'm in the UK too!!!! Generally speaking the cost pf packing, shipping repair, at any level is well on the way to the price of the next more recent higher specification device. Judging by the way the Megapixels go up by the week seemingly, settling for a replacement camera is usually the best option. I had a cheap[old] Fuji come my way because it had gone blurred and blue - sure sign of a CCD failure as this was at some time the subject of a recall for the problem I checked out Fuji Their response was to say no longer repaired but has a 1/3 off a new camera when I quoted a reference number. That seems to be the way to go.
SOURCE: Canon EOS-300D not seen by computer/not turning on
Heat and batteries - maybe Try another battery Remove camera software from computer and put the disk in the box. Plug camera in switch it on and set it to upload mode Windows should find it as a new drive or[XP/2000/ME] will put up camera/scanner wizard.
SOURCE: canon powershot a95
Think you may have bent a card pin. Remove the card and the camera's batteries. Look in the card slot for any bent pins. If you see one, don't fret, it may be fixable. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible (one from the dollar store is fine for this). Take your time and use as much patience as you can muster. Take a breather in between if needed.
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If there are no bent pins in the slot, then the next obvious thing to try is a different CF card.
SOURCE: I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
