You can deal with every stain that appears on your carpet if you keep calm and act quickly.
Step 1: Grab a white towel and gently take away the liquid.
Step 2: Pour some baking soda on the stain.
Step 3: Leave it for a few hours.
Step 4: Rinse out the surface with a calm water and white towel.
If this doesn't work, call the experts at 1st Carpet Cleaning.
We bought a Vax Rapide Carpet Cleaner and were disappointed with it's performance as we couldn't see it spraying the cleaning soltion onto the carpet. I found there was no pump and gravity was all that put the solution on via a sparge pipe, controlled by a trigger-operated valve. So, all that happened was an intermittent sort-of dribbling. The cleaner picked -up quite well, though and we sprayed the carpet using a separate hand-held sprayer.
some models take special sollution so not to clog up solonoid for the jet pat attention ti the solonoid.soak in very warm water then accuate it in soak fluid if possible
