Why my tablet cant charge but the indecator of tablet is charging but the battery cant load voltage?
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
SOURCE: new battery will not charge, shuts down
have you tried connecting it up, leave it for say 8 hours and don't use, try it then?
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
