Try different unlock patterns. Once it rejects you it will ask you to sign in to your google account. Type "null" in the user name line and "0000" for the password. I was locked out of my android phone and used this to get past the unlock pattern and back in to my phone.
SOURCE: I need to reset my tablet to set a new pattern to
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
SOURCE: I have locked my MID Android Tablet. I have
pls try reset your mid tablet pc, if it can't, maybe you can contact your seller. if you can't contact your seller, you can ask another mid tablet pc seller online help sevier. as: http://www.mcwto.com, they are an mid tablet pc wholesaler.
SOURCE: I can't get my tablet unlocked(dot pattern) any ideas?!
On an android tablet there is generally a button combo, you can google your specific model for the answer. For instance, you might turn the tablet off and then hold the power button and the volume up or down button.
SOURCE: My zeepad 7.0 tablet want go past the andriod
You need to do a factory reset.
SOURCE: sound problems on tablet
It sounds as though the switch on the phone jack is not making connection when the phones are unplugged. You can probably clean it by spraying some contact cleaner in the jack, then plug and unplug the phones several (lots of) times. I've had good success with WD40, but it does leave a residue. If this does not fix the problem, you can open the tablet by gently prying the screen off with thin blade (a knife might work). Work your way around the entire screen until the body separates. Gently open and perhaps you can access the jack switch to clean it, if it is not sealed. I hope this is helpful to you.
