Need the wires to this unit I made a mistake and threw them away when I moved does anyone have a number to apex I do not want to throw it away never used it but once
I guess this is not going to help for the one who originally asked the question, but I have recently done the same mistake and managed to recover my device. Hope this is going to help anyone out there.
Prepare a pendrive with a proper firmware version and follow the bullets below at your own risk (although you probably got nothing to lose at this point):
Disconnect the device from power supply
Use a screwdriver to remove the black lid
There are two PCBs lying in there connected to each other by three set of wires.
Disconnect the set of wires which is closer to the front panel (one side should disconnect quite easily)
Plug in a pendrive with a proper firmware version
While those wires are still disconnected, connect the device to power supply and then turn it on
It should boot properly and load the firmware from pendrive
When firmware loads successfully, turn the device off, unplug the pendrive and close the lid.
Congratulations! you have just restored your STB236 !
tHIS INFO ONLY AVAILABLE AT A CADILLAC DEALER PARTS DEPARTMENT YOU NEED DRIVERS LICENSE, PROOF OF OWNERSHIP BESIDES KEY CODE YOU WILL ALSO NEED THE CHIP NUMBER
need constant hot and a neautral plus your load and the rest is self explanatory screws should be color coated blk constant hot copper load silver neautral
I had a paper for a remote... think it is the phillips universal remote.
it said apex tv codes were as follows: 023 and 741
apex audio is: 068
apex dvd is as follows: 044 146 347 545 547 640 644 740 741 840
there are no part number because there are no parts available. but if you are getting an overheating message, move the sensor for the front fan or remove it altogether (cut it off, jumper the wires, and tape them up well. and make sure they are away from the fan).
you can purchase the fly back from systems innovation on half way tree road. they order it for you and it takes two weeks for delivery. cost eighty nine united states dollars and that includes shipping costs.
