Washing Machines Logo
K
Kricket B Posted on Nov 06, 2014
LG no power unless I unplug it and reset it. Help please!
Front load washer, 3-4 yrs old, only starts after reset, will wash one load and then needs to be reset again before it will turn back on.
jralegriam
Level 1:
  • Contributor 25 Answers
  • Posted on Nov 17, 2014
jralegriam
Contributor
Level 1:
Answers
25
Questions
0
Helped
8192
Points
41
The control panel has a problem, check it or replace it
5 Related Answers
Anonymous
  • 100 Answers
  • Posted on Dec 05, 2007
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Anonymous
  • 96 Answers
  • Posted on Mar 31, 2008
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Anonymous
  • 66 Answers
  • Posted on Jan 15, 2009
SOURCE: no power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Anonymous
  • 236 Answers
  • Posted on Mar 18, 2009
SOURCE: servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Anonymous
  • Posted on May 07, 2009
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
LG washing machine fix unplug plug in works
Question makes no sense as written. Is this what you mean?
We have to unplug the washer and plug in everytime ...
JustAnswer https://www.justanswer.com > Appliance Repair
Dec 12, 2020 - Unplugging the washer will reset the issue one cycle at a time, but to fix the issue completely the main board will need to be replaced. This is ...
1 answer · Top answer: This is a very common way for front load LG washers to fail. The problem is that the main ...
WM3470HVA LG Washer won't turn on until I unplug for 10 ...
Appliance Blog https://www.applianceblog.com > ... > Washers > LG
Jan 8, 2017 - My LG Washer just started an issue where it won't turn on when pressing the power button. But if i unplug it for 10 seconds, then plug it ...
FIXED - WM3360HVCA LG Washer Won't Power On
Sep 30, 2019
WM3470HWA LG Front Load Steam Washer Won't Turn On
Aug 17, 2016
More results from www.applianceblog.com
It appears to be a VERY well known issue!
https://www.google.com/search?q=LG+washing+machine+fix+unplug+plug+in+works
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
My wm2455h turns on by itself and after some time, it turns off. What is causing this>
It seems that the Main Control Board of your washing machine is playing up. The fact that when you unplug the machine from the mains, the main control board resets itself and you are able to start the machine points in this direction.
1helpful
LG washer #WM2655HVA won't start again after a cycle, unless unplugged, hand-turn drum, makes a beep, static spark as plugged back in, then a new cycle begins. Why?
Have you checked the wall power outlet for proper ground and
polarity? Try using another outlet near by using a "heavy duty"
3 prong extension cord. If problem persist chances are the Main
PCB is bad.
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Lg steam washer 2yo 3 yrs old . Refresh cycle produces bribble of water rather than steam and leaves clothes wet
The steamer unit may be overfilling. Check the water valve and see if it leaking. If it's ok, you will need to replace the steamer unit. Good luck
2answers
Le code drum only turns one way
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Is this a new installation?
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Thanks for using FixYa*&^%
Electronic display was flashing LE. Unable to open front load washer...no visible water. Tried to restart...unable. What is your best solution to open front and get washer working again? washer is...
Waht make? Model?
Sounds like an LG
You might want to unplug the unit for 10 min -then plug it back in and then power up , then press pause.
LE- could be a motor sensor, main board issue - wiring issue
Affordable Appliance repair
Orange County, CA.
2helpful
No power
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
