What line on back the frig i need hook up water to
SOURCE: Model msd2651kes Water supply
If when first hooked up the water line if you used a peircing type valve that clamps onto the cold water pipe it clamps on,tighten the screws equally on both sides till its tight around the pipe.Turn that handle in to peirce the pipe in a clockwise motion till it stops,it will peirce the pipe but be in the closed position, so open it in counterclockwise direction till it stops
Gene
Thanks BJ this is Maytag MZD2766GES, there are 2 line look at the back from LH to RH, smoke clear, then gray i connected water supply to this one and turn on, water come out on clear smoke line, haha...
