Drills Logo
R
Regena Sword Posted on Nov 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased a Black & Decker DR260B drill to drill masonry but there's no info in manual about brick. Can I use this drill to drill holes in brick mortar?
Jim Jordan
Level 3:
Master:
  • Master 442 Answers
  • Posted on Nov 07, 2014
Jim Jordan
Master
Level 3:
Master:
Answers
442
Questions
0
Helped
114765
Points
1360
This corded drill has enough power to drill normal brick masonry without issue as long as you're using a masonry bit.
http://www.homedepot.com/b/Tools-Hardware-Power-Tool-Accessories-Drill-Bits-Masonry-Percussion/N-5yc1vZc23f
5 Related Answers
efs_perpends
efs_perpends
  • 1997 Answers
  • Posted on May 27, 2009
SOURCE: Black & Decker model 4300 manual
Here's a link to a downloadable .pdf manual for your sharpener that will give you pages and pages of instructions to make those dull bits history.
Enjoy!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Anonymous
  • 1124 Answers
  • Posted on Sep 10, 2009
SOURCE: my chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
Anonymous
  • 108 Answers
  • Posted on Oct 11, 2009
SOURCE: how do I change my black & decker electric
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Anonymous
  • 37 Answers
  • Posted on May 29, 2012
SOURCE: what is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
Anonymous
  • 32281 Answers
  • Posted on Jun 04, 2012
SOURCE: Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
1helpful
2answers
How would I correctly attach a board, horizontally, to a brick wall? I want to hang my shovels, rakes, and other tools, under the eve of the house to get them off my patio.
Hello, Nancy -
I suggest you pre-drill holes in the wood -- evenly spaced holes, all in a row, so that later on you can drill screws into the concrete anchors you will drill into the brick or the concrete between the bricks.
After pre-drilling holes in the wood, measure how far apart the holes are. Determine where on the brick wall you want to drill to insert the concrete anchors (which will accept the screws to hold the wood on the wall). Mark on the brick wall where the drilling for the anchors (to match up with the holes drilled in the wood) should be. Drill into the brick or cement between the bricks.
Then, assuming the hole measurements on the wood match up to the drilled holes in the wall, attach the wood to the wall with the proper anchor bolts/screws.
You may find these directions for attaching a ledger board to a masonry wall instructive:
https://www.doityourself.com/stry/how-to-attach-a-ledger-board-to-a-masonry-wall
Best wishes.
Oct 12, 2018 • Drills
Black and decker hand prep express model hb5500w wont work
When you are working with brick or concrete, you should check out the Black & Decker DR670 Hammer Drill. It is specifically made to tackle this purpose.
Jul 14, 2017 • Hand Tools
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Before the invention of the hammer drill, people face a lot of trouble drilling in the tight spaces. They had to break down the parts in smaller units in order to drill it properly. But, now the time has changed and the users can easily drill on a portable manner. But, one might wonder, what makes the best hammer drill
? The answer is being more and more complicated each year with so many brands on the market.
The market offering is huge and most of the brands are continuously reinventing their products. We have analyzed many different drills from cordless hammer drill to a corded hammer drill, to hammer drill machine to cordless hammer drill drivers. Thus, we have come up with these top picks.
2helpful
I have a Black & Decker 12 volt cordless power/hammer drill. I think it needs a new battery & possibly changer. Can I purchase a new battery & charger or is the drill too old?
try this parts supplier
Black and Decker Cordless Drill Parts
see if your model has a parts list for battery and charger
if discontinued
look for tha same used drill in better condition
or toss in the bin
Oct 20, 2016 • Drills
2answers
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Black & Decker electric planer manual
what are you asking for? a manual for a Black & Decker planer if so there is a website called "produtools manuals 2.1" it has many manuals for many differant items. Goood Luck
Need manual for Black & Decker drill/driver no. 9021
Go to the Dewalt ServiceNet website at http://servicenet.dewalt.com/. Put your model number in the parts search box and you'll be able to view or download the manual and parts breakdown.
1helpful
How do you turn it on?
Click on the link below to access the Black & Decker Pivot Cordless Drill/Screwdriver owners manual, inside this manual will show you how to turn it on:
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/5145342-00,PD600PD600G.pdf
1helpful
I Own a U21 Black & Decker Drill Type AH070865 I need to get the stator completely fixed infact a wiring diagram would be great, or a repair manual
Go to www.2helpu.com which is the Black & Decker after sales service site. Most, if not all diagrams are located there, including manuals
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
