Need to adjust carburator air fuel ratio
These tools are not available to the public. There is a specific penalty that can be levied if the owner adjusts these screws. A local dealer should make the adjustment.
The tool is not available through Husqvarna.
It should be a spline tool. It is the most common one.
Genuine Poulan Weedeater Part 530035560 Carb Adjusting Tool
If you work a lot 2 cycle trimmers and chainsaws you might buying the set of four adjustment tools.
2 Cycle Carburetor Adjustment Kit Includes 530035560
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
SOURCE: can't find a husqvanna chain saw carburator
You may have the one that uses splined adjustment screws rather then limiters.If you do you can order this from your husky dealer.You can tell if you have limiter caps by shining a light through the screw hole and see if caps are white or red.If black you have round splined needle ends that take a hard to get adjustment tool.
SOURCE: What tool do I need to adjust the high & low
Should just be a little bladed screw driver, most are, turn the screw very little, 1/4 turn at a time till something changes, they are sensitive. If you run out of adj and nothing has changed, turn the screws in all the way, both of them, then out 1 1/2 turns, this will get you running, you can fine tune from there.
SOURCE: how to adjust the carburator
Unfortunatly there are special tools required to adjust the screws, the screws are set from the factory for the best emmisions. The screws are anti tamper with splines rather than a screw driver slot, before making any adjustments check fuel filters and hoses first, it is not good to try and compensate for fuel blockages by richening the carb, max rpm must be set up useing a engine tahco and should not exceed 12500
SOURCE: I have a husqvarna 435 chain saw and need to
There is a special tool required, the part no is 530035560 available from Husqvarna/Jonsered dealers, as posted earlier this should be a dealer adjustment as the machine is new.
