F17 is water not coming into the appliance . if the appliance is ok when you use the wash cycles the fault will be with the valve on the drying cycle or your pcb . your inlet valve is a triple valve . 1 for the main wash and 1 for the pre-wash which are used for your wash cycles .the third one is for the drying cycle . it uses the water to condense the steam on the drying cycle . unplug the appliance . remove the lid . the inlet valve is at the back right . the far left one is the drying valve .It is more common that is at fault than your pcb . The only way you can be sure is with the use of a multimeter . you can do this with the power off .if you have access to one remove the 2 connections and measure the continuity (ohms ) across the two points . if it is open circuit ( no reading ) then that part of the valve is faulty . be warned though , this part can still be faulty even if you have a reading . if you or someone you know is competent with using a multimeter you can re-connect it then turn the appliance onto the drying cycle and see if you have voltage to the part . all that said if you lack experience fit a new valve . it is quite a common fault .
SOURCE: How can I turn off the beep sound on my exxcel
I've just found my instruction manual and managed to turn the volume off on mine after 6 months of annoying beeping.
You turn the programme selector to off then turn it one programme to the right, press the rpm button and keep it pressed while turning one more programme to the right, release them both and a number should be displayed on screen I think volume 2 is the default one. You then click the "ready in" button until desired volume is reached. You have a chioce of zero through to four. After volume is set turn programme selector to off position. The annoying beep should be no more!! Hope this helps others.
SOURCE: Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
SOURCE: Bosch exxcel wvt1260
I have a Haire combo unit. (washer/dryer) The dryer is a condenser type. I had a this problem with the dryer part of my unit. It was still under warranty at the time so naturally I called. When the tech came out he discovered that the heating element had melted the fan all over the blower elements. this problem could have been fixed, however, Haire came out with a newer model and couldn't get the parts anymore because they weren't making them anymore. Needless to say that totally sucked. But, at least the washer still works great. Upon doing a little research, I discovered that most condenser dryers do get too hot to support one or more of thier internal elements. I would not get another dryer like this without asking about this problem and if there has been any rectification of this issue and how so.
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
SOURCE: USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is [email protected]
