Alesis Sr 16 Stereo Drum Machine Logo
D
Deon L Posted on Nov 08, 2014
ALESIS SR-16 won't save patterns
I am having a couple of problems with my ALESIS SR-16 drum machine. Firstly, when I create a song/pattern, it only saves songs for MAYBE a few days and then it completely vanishes off the face of the earth. This is super annoying and has bitten me on more than one occasion. Secondly, my ALESIS does not have a Backlight. HELP
Chris Varnam
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Nov 09, 2014
Chris Varnam
Contributor
Level 1:
New Friend:
Answers
24
Questions
Helped
7248
Points
36
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
On a alesis Sr 16 drum machine Can u make a song list so the drums will play one after the other without having to recall each setup before each song. Like making a song list
If I remember the SR16 correctly, the answer is sadly, no. The SR16 will let you assemble a series of patterns into a song like order, but it won't link them. You'd have to change patterns when needed.
How to do a factory reset on a alesis s r 16 drummer
Power up while holding play-erase. BUT...when performing a re-initialization, this will erase all existing patterns, songs, and drum assignments. This will not erase the factory preset patterns or kits.
http://community.alesis.com/alesis/topics/sr-16-factory-default-reset-question
1helpful
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
How do i ceeate and save a waltz pattern on my sr 16 drum machine ?
go to the ballad #4 setting you will find a 3/4 beat in a 12 beat time.
This is a preset pattern
I have a song which is the same pattern right through and i want create some pauses
Audacity is an audio editor that will allow you to do that. It's a free download
1helpful
None of my patterns save when turned off.
Likely the memory backup battery is exhausted. Replace it.
The only other options is to dump data to external recorder and reload as needed.
How do get this machine to do 3/4 time?
go in and create your own pattern, set the time signature to 6 beats per measure
Question on the start /stop feature and saving tempo information
As I read the manual, the tempo is saved with the SONG.
Starting and stopping rhythm SHOULD always start at the begining of the song. This is on page 20 of your manual. The manual is available online if you don't have one.
Top Alesis Music Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Alesis Music Expert? Answer questions, earn points and help others
