ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Hey Brenda, thank you for your post!
Based off the information you have provided you would like to read the error codes on your Frigidaire washer. What kind of codes is your washer displaying? I was unable to locate a list of codes. If you can provide me with further information I would be able to assist you. -Matt
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
I appreciate your inquiry, friend!
Based off the information you have provided your Frigidaire dishwasher is displaying an error code of "5H". That appears to be the time remaining on your wash cycle. Typically an error code would be displayed with a number and an "E". What is the current problem with your dishwasher? Are you getting long wash times? There is a sensor inside of your dishwasher that reads how dirty the water is, if your dishwasher continues to circulate dirty water it will tell that sensor to continue washing. You may want to check your filter, which is located at the bottom of the tub, for any debris. Additionally, if your drain hose is restricted it may be providing dirty water back into your tub. I hope this information is helpful to some degree. -Matt
