The Express 795 was a relatively low end unit made for Radio Shack and it satisfies my needs as I am only an occasional speeder and may occasionally go 5-10 miles over the speed limit on the interstate. Still, the alerts are a comfort and it is great to know where "the boys" are so I can be sure to check my speed. The 795 handles K and Ka bands and is more than adequate for this so I don't need to invest in an expensive detector to get this peace of mind.
SOURCE: Beltronics Vector 985
If its still under warrenty Call Beltronics 800-341-2288 I had the same problem and they re-tuned the Detector and updated the firmware my Vector 985 was out of warrenty by 5 months and Bel repaired it for free. Hope this helps
SOURCE: Need Help with my radar detector
Bel/Escort now use a special "high temp" speaker which resolves issues of blown speakers. They can replace the blown speaker inside your RD.
SOURCE: no audio
Hi everyone,
Bel/Escort now uses a special and proprietary "high temp" speaker which resolves issues of speakers blowing due to high ambient temperatures or heat which builds up within the speaker when it is alerting for extended periods of time. If your RX65 is in warranty and you can make a photocopy of your sales receipt, then great! All you have to pay is shipping to Bel. Bell will replace the speaker with the new version, flash your RX65 with whatever the latest firmware is, and calibrate and test your RX65 too. So, all of this is peachy if your RX65 is under warranty.
If your RX65 is out-of-warranty or if it doesn't have a serial number or was bought from a non-authorized dealer, then the service charge as I recall is $80. Thats not bad since your RD will come back working like brand new.
A note about the speakers: They are made by PUI, but the speakers are proprietary to Bel/Escort. Thus you can not buy them from any source -- not even direct from PUI.
SOURCE: BELTRONICS 940
This is a somewhat common problem that occurs when a strong voltage spike while starting your car damages the radar detector. Bel can fix your RD. Once you get it back, always start your car first before powering on your radar detector. Likewise, power off your radar detector before turning off your car's ignition.
