Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
You can only print on envelopes with the computer.
Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive
Prepare envelopes.
How to load envelopes in a canon mg3250 printer - c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.giflclip1\01\clip_image002.gif" alt="c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif" class="h_mi" /> Press down on all four cornerHow to load envelopes in a canon mg3250 printer - c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gifads/images/c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif" alt="c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif" class="h_mi" /> If the eHow to load envelopes in a canon mg3250 printer - c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gifem in the opposite direction.
If the corner of the envelope flap is folded, flatten it.
Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm).
Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed prHow to load envelopes in a canon mg3250 printer - c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.giftil the top of the stack touches the paper guides.
(5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
Be sure to open the paper output tray when printing. If not open, the machine cannot start printing.
After loading envelopes
Select the size and type of the loaded envelopes on the print settings screen of the printer driver.
You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
For details about how to load an envelope into the printer, see
the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear
tray, orient the envelope so that the flap is on the left and the folded surface
is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the
Main tab.
4. Click the Page
Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape
for Orientation.
6. Click OK.
When you execute print, the information is printed on the
envelope.
