Its a frigidaire stacked washer/dryer with model # FEZ831CAS3.The dryer is spinning but the heater is not working.The manual states that I have to replace the fuse/s.Where can I locate the fuse/s?
There are no user servicable fuses in the machine, I believe they are talking about your breaker box.
A 220 dryer requires two 110 volt circuits to run the 220 volt heater
The motor and control circuits only require 110 and are run from only one of these two lines. If the other line blows the dryer will still run but there will be no heat.
Good Luck
Quentin
Hello April Tucker - Generally speaking, Frigidaire laundry centers do not have fuse. The unit has a thermal limiter usually located in the dryer.
