We have a Frigidaire top freezer refrig. Freezer is cold enough even though it has some ice buit in back wall of freezer but refrigerator is not cool enough, few days back i removed the freezer back wall and found the vents that flow the air to the refrig. was blocked with ice, i cleaned it start cooling but not enough, now it stop cooling refrig. again.?
Check out these tips...they can help you figure out whats going wrong...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in Refrigerator from
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
THE HEIGHT OF THE SPACE MY REFRIGATOR NEEDS TO FIT IN IS NOT HIGH ENOUGH. I NEED TO SHORTEN THE HEIGHT OF MY REFRIGERATOR
