It appears as if Onkyo TX-DS575 infrared receiver does not function. I tried new batteries in the remote. The stand-by light does not respond as I believe it used to. The remote works on other components such as the DVD player and the cable box as I programmed the macros in the remote. So it would appear as if I need a new IR sensor in the unit. I would appreciate any help in diagnosing other problems which may mimic this situation. I would also appreciate any help in describing the procedure in going about replacing the IR sensor ie part #, pitfalls, tools needed.
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Onkyo-TX-DS575x-Receivers-review-manual/id/365dj179/t/1-2/
The remote is RC-391M
Original $80
http://cgi.ebay.com/RC-391M-ONKYO-HOME-THEATER-CONTROLLER-/120686595599?pt=LH_DefaultDomain_0&hash=item1c197b4e0f
substitute remote $58
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A12986292726381&smodel=TXDS575&brand_pn=ONKYO_TXDS575
