Question about Intuit QuickBooks Computers & Internet
I need to open a quickbook 2003 pro edition file
    Champion:
  • Intuit Expert
  • 237 Answers
You would need QuickBooks Pro 2003 or higher to open that file.
Posted on Jan 06, 2017
6ya staff
SOURCE:
Anonymous
  • 32 Answers
SOURCE: Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Posted on Feb 18, 2009
Anonymous
SOURCE: is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Posted on Apr 06, 2009
Anonymous
  • 21 Answers
SOURCE: quickbooks pro 2005 I cant open my backup files
You are not able to open a backup file in Quickbooks, Only restore it, to open a previous backup, the easiest way is to make a copy of your current company file, then restore the backup over it. This will give you a company file with the backup data.
Posted on Nov 28, 2009
SOURCE: I just downloaded QuickBooks 2010 EasyStart, and
You have to unistall the 2010 Simple Start program. It creates a conflict.
www.cpahispano.com
Posted on Aug 08, 2010
mubashsher
mubashsher salim
  • 50 Answers
SOURCE: Quickbooks Premier 2008 will not open quickbooks
PLEASE REMEMBER THERE SHOULD NOT BE ANY PROBLEM IN OPENING A QB PRO 2008 COMPANY FILE IN PREMIER 2008. THERE SHOULD BE SOME OTHER REASON TO IT .
If you need the resolution, please reply with the foll :
1. Which Windows Version you have . Is it Win XP or Vista or 7?
2. How do you try to open the company file ? Please list the steps .
3. Do you get any erro msg ?
4. Does QB crash?
5. Do you have a backup company file QBB or main company file QBW ?
Please try these steps or reply to my questions:
1. Change the location of the company file.
2. Disable UAC.
2. Rename the company file .
3. Delete the ND and TLG file .
Posted on Nov 27, 2010
Error 1334/ quickbooks pro 2008
Solution 1: If you get the error while launching or opening QuickBooks
Find and open your QuickBooks company file. It has the file extension .qbw.
Double-click the company.qbw file.
Solution 2: If you get the error when updating or repairing QuickBooks
Please see Error: 1334 while repairing or updating QuickBooks for steps to resolve.
Solution 3: If you get the error when installing QuickBooks
Please see Repair or reinstall Microsoft .NET Framework for steps to resolve.
for more help visit
QuickBooks Technical Support
May 17, 2010 | Intuit QuickBooks Pro 2008: Windows
Unable to retrieve company file after closing it
You probably opened an old file. You will need to find the current file that you were using. Use the search and search for all files ending in .QBW
Check the dates they were last used (you don't want the one with the most current date since that was the old file that was opened.)
Feb 17, 2009 | Intuit QuickBooks: Pro 2005 for PC
My QB crashes everytime I try to invoice...only with one company, but with others it runs fine. Problem is i need the giles from that one company, What do I do?
You should verify your data file (Click on file, click on utilities, click on verify data) If quickbooks doesn't find any problems, Back up your company to a different location and if your using 2006 or higher, create a portable file, close quickbooks, reopen quickbooks, and then click on open portable. When it prompts you to backup, click ok and back up again using a different file name.
You then need to go to templates, and (sorry to tell you this ) change each one to the default setting (click on lists, click on templates, the click on templates at the bottom, and click on edit, click on additional customization and then default. Then click save and close. Do this for all templates.
Also resort each list (item customer and vendor) to their original order.
Close the file and then reopen and verify data - if this doesn't fix the problem you will need to contact a pro advisor or intuit for aid in fixing the file
Jan 30, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
Problem reinstalling Quickbooks 2003 in XP Home
The newer versions of QuickBooks should be able to read the older versions files. You may get a message about updaing the data.
Many people have been reporting issues with Xp after service pack 3 came out, and was then pulled by Microsoft.
If your system did get the service pack 3 update, it may actually take a microsoft tech to undo the update successfully.
Jan 07, 2009 | Intuit QuickBooks Premier: Accountant...
Is quick books 2003 Vista compatabile?
Feb 14, 2008 | Intuit QuickBooks Pro 2003 Single User...
Open Questions:
00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Feb 02, 2019 | Intuit Computers & Internet
Computers & Internet Logo
148 people viewed this question
Top Intuit Computers & Internet Experts
NET MAN
Level 1 Expert
Ekse
Dalynn Turner
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
