Question about Boating
Hi I was wondering if anyone has a wiring diagram for a honda b75 outboard engine. I have a black wire from the valve pulley, a black wire from the wiring harness below the crank pulley, a white wire
I've put the problem in the top info box.
  • 3,103 Answers
Go to honda outboards in the search.. see if you can download a printout.. you may need to call your dealer see if they can get one also..
Posted on Dec 12, 2014
6ya staff
SOURCE:
Thomas F. Schneider
  • 2715 Answers
SOURCE: gear box oil leak
Here is a website where a manual for you outboard may be purchased.  Outboard Marine went out of buisness in 2000 and thus no parts of origial manufacture are support is available . Therir are secondary markets .    THe Lower case splits in half and their is a seal around the prop shiftm which is pressed in. The seal between the cases are cut o-rings which are placed and glued into place with gasket seal.
The water pump is located where the case splits a little bit higher. You must open the little port on the side and take out one of the screws to the connecting shift linkage to split the case. After splitting the case the drive shaft and water pickup tube(s) wil come out of the powwer head or the tubs may stick into the power head which is ok. Place the lower skag into a vice and remove the 4 or 5 screws to the water pump housing. Remove and replace impellor and impellor plate if available. If part(pieces) of the rubber impellor is missing flush out the tubes and the power head to remove them.   When reinstalling the lower unit use a flash light to make sure that the tubes return  to the proper place in the power head and the shift lever is resecured. If you need more assistance, just write back. I was an Outboard motor mechanic for five years about the time of your motor.
Posted on Dec 23, 2008
fordexpert
  • 5692 Answers
SOURCE: turn the switch off motor keeps running
It sounds like there is a short in the alternator or wiring for alternator. You are continuing running with the battery cut off. But the outboard generates its own power and its finding the way to the ignition. As for grounding, you may be idling too high for a quick shut off.
Posted on Jun 18, 2009
Anonymous
  • 77 Answers
SOURCE: Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Posted on Jun 21, 2009
Anonymous
  • 86 Answers
SOURCE: MERCURY OUTBOARD 50HP 1974 NO SPARK
Clean or replace and set points to .020. Also replace your condenser.
Posted on Aug 11, 2009
Anonymous
  • 3 Answers
SOURCE: iam looking for a wiring diagram for a 1964 40
Here is a link to the diagram you need.
http://www.maxrules.com/graphics/omc_pics/wiring/61_66_40HP.jpg
Posted on Apr 28, 2010
2000 Honda VT 600 C Shadow wire diagram
Hi, Danny for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2000 Honda VT 600 Shadow wire diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda VT600C Shadow VLX Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT600C Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 04, 2018 | 2000 Honda VT 600 C Shadow
2005 Honda NF 100 Wave wiring diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2005 Honda NF 100 Wave wiring diagram Google Search
http://www.ethicalbox.co/honda_wave_100_service_manual_download.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda Wave 110i User Manual
Oct 14, 2013 | 2005 Honda NF 100 Wave
Honda b75 twin
Hi Graham,
The Factory Normaly Put a Sticker On The Top Engine Cowl Giving
Oil Quality And Engine Oil Capacity.
You Could Drain And Then Add The Correct Amount!
This Would Clarify What They Are Getting At.
There Must Be a High Full Mark And A Low Add Mark
The Figures In Between Must Be A Suggested Amount To Add To Reach The Full Mark
Hope This Helps
Regards
Gordon
Jun 15, 2013 | Light Outboard Motor Boat Bass Fishing...
1994 Honda VT 1100 C Shadow wiring diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1994 Honda VT 1100 Shadow wiring diagram Google Search
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Feb 21, 2012 | 1994 Honda VT 1100 C Shadow
Honda VFR400K wiring diagram
Hi, Mainten650 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
Honda VFR400K wiring diagram Google Search
Honda VFR400R Service Manual
Honda VFR 400R Make Model Honda VFR 400R NC30 Year 1992 Engine Four stroke...
Feb 11, 2012 | Honda Motorcycles
2000 Honda CMX 250 Rebel wiring diagram
Hi, Frederick the black wire is ground for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
2000 Honda CMX 250 Rebel wiring diagram Google Search
Rebel CMX250 250 1985 2009 Motorcycle Service Repair Manual Download...
Honda CMX250C REBEL 2007 Owner Manual
Sep 29, 2011 | 2000 Honda CMX 250 Rebel
2005 Honda Dio wiring diagram
Hi, Argonz17 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
2005 Honda Dio wiring diagram Google Search
Honda SK50M Dio Service Manual
Honda SK50M Dio SR 2000 Owner Manual
Nov 02, 2010 | 2005 Honda Dio
WIREING A 1P52FMH ENGINE TO A HONDA 1973 CT-70 trail bike..
Hi, Harroknec the answer to this question is way above my pay grade and for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
1P52FMH ENGINE wiring diagram Google Search
1973 honda ct70 wiring diagram Google Search
Honda ST50 Shop Manual
Honda ST50 Owner Manual
May 01, 2017 | 1973 Honda CB 100
How do you set the timing on a 92 honda prelude
Hi there. Firstly you need a strobe light, I hope you have one of these. Firstly when the engine is stopped, you need to locate the timing marks on the crank pulley - they are a series of indentations on the crank pulley and you will see the pointer on the crank pulley cover. The largest indentation on the pulley is TDC (Top Dead Centre) and the three smaller indentations are your timing marks. When the engine is at normal operating temperture and idling, using the strobe light, the centre small timing mark should be aligned with the pointer on the crank pulley cover. If it's not aligned, loosen the distrubutor body and turn in the appropriate direction to either advance or ****** the ignition timing. Hope this helps, Scottech.
Apr 04, 2009 | 1992 Honda Prelude
1985 Honda VT 250 v twin wiring diagram
Hi, Cschaefe for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1985 Honda VT 250 twin wiring diagram Google Search
Honda VT250 FII Shop Manual
Honda VT250 FII Owner Manual
Oct 18, 2017 | 1985 Honda VT 250 F
Boating Logo
117 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
