Cars & Trucks Logo
Javaris Kornegay Posted on Nov 19, 2014
03 Cadillac CTS passenger seat won't recline - Cars & Trucks
Hamid Akhtar
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Nov 19, 2014
Hamid Akhtar
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
6714
Points
39
Many possibilities for that, its an 03, the channel could be stuck, the motor could have gone bad, the switch could have gone bad, a fuse or a relay could have gone bad. Your best bet is to look if the channel is clean and nothing is stuck there then look for a faulty fuse, and if that is okay then you can check if the switch is bad, by swapping it out with an aftermarket or a part from the junkyard, next comes the electric motor for the seat.
5 Related Answers
Anonymous
  • 405 Answers
  • Posted on Dec 22, 2008
SOURCE: 03 cadillac cts timing belt change procedure
if you know you can do this with directions and go to alldatadiy.com and buy a subscription, you will be glad you do, it is beyond the scope of this forum to tell you. But for 20.00 you will have exact precedures, step by step, and lots more on your car, It's worth it, I promise, If I have not helped you, please do not rate me, If I have please vote fixya. It's the only way you can pay be back for free. God Bless Good Luck, and Merry Christmas!
Anonymous
  • 5158 Answers
  • Posted on Feb 01, 2009
SOURCE: T/C light comes on in the dash of my 03 Cadillac CTS
T/C would be traction control i would think
Robert
stevieger
  • 184 Answers
  • Posted on Feb 11, 2009
SOURCE: my front seats on my fiesta 54 reg are broken i have to recline t
I TAKE IT YOU CAN'T USE TILT ON YOUR SEATS MOST LIKELY TO BE BROKEN CABLES YOU WILL REQ CABLES & BOTH SEAT HANDLES TO DO JOB OULD NOT RECOMMEND IT THOUGH AS ITS A PAIN OF A JOB TO DO.RECOMMEND BOOKING INTO LOCAL FORD DEALER AS THEY PROBABLY HAVE PARTS IN STOCK.
kirtec auto
  • 1348 Answers
  • Posted on Sep 14, 2009
SOURCE: 2005 cadillac cts has the airbag light on , i
the computer knows that input data from a system has a problem,so disconnecting the battery will not help.
that is the procedure for working on it so that the airbags do not deploy.
a code scanner will tell you which part of the system,including a seatbelt latch,tensioner, or seat position sensor is defective.
Testimonial: "thank you for your help , but i was trying to avoid paying to the " scanner ""
craig
  • 14 Answers
  • Posted on Jan 06, 2010
SOURCE: where is the thermostat on an 03 cadillac cts
no the thermostat is not always in the upper radiator hose
How do you get the H/A to reset 07 cts
How to Change the Bulb in your 03-07 Cadillac CTS Fog ...
? 4:13
https://www.youtube.com/watch?v=TaW1haYSThs
Oct 13, 2011 - Uploaded by 1A Auto Parts
How to Change the Bulb in your 03-07 Cadillac CTS Fog, Daytime ... Do you guys have video for replacing the turn signal bulb in a 2006 STS?Missing: h
Re: Reading/Clearing Diagnostic Trouble Codes (DTC) - Cadillac
Fule pump relay location on 2003 cadillac cts
Here is the text version, and I will get the photo location also. "It is located in the rear fuse block in the passenger compartment under the rear seat."
6helpful
3answers
2005 cadillac cts has the airbag light on , i tried to diconnect the yelloy connectors under the passenger seat ( since even when a passenger is seated , the passenger airbag is off ) , to disconnect the...
Hot air blowing out on passanger side only, 03 Cadillac CTS
junk it its not worth it one of the sensors that open and shut the door are bad
CTS passenger seat belt
Hi,, try pulling the seat belt slowly,
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
